rtv-500
silver
rtv-500
Jun 5, 2026
texas
blows one fuse everytime you turn ignition switch its the fuse that powers the engine control, fuel pump, radiator fan went through the whole harness and didnt find a short also replaced the fuel pump and ign. switch help
silver
rtv-500
Jun 5, 2026
texas
Hey mike thanks for the help let me tell you what happened . i had put a battery cutoff down by the ebrake
while i was riding it i thought my ebrake was on so i reached down and hit the cutoff at full speed and it shut off stoped and fliped the cutoff on and wouldnt start at all. checked fuel pump not working checked
fuses and a 10 amp was blown it runs the ecu,fuel pump, fan motor relay. replaced it and as soon as i turn
ignition to on it blows every time. i replaced the pump check all the harness shorts do you think ecu shorted out
