L3400 hydraulic pump location
thetomtom
L3400
Jan 27, 2026
Usa
Pre 2008 l3400 with front loader bucket and pto and 3 point hitch. The rear wheels are always running and I have the option of having the front wheels powered.
I need to find the hydraulic pump and filter. Im pretty sure it's frozen or sucking air somehow. It happened once years ago.
My father tells me to look for a rubber drain hose. But that leads me to a rubber hose near the front axle and the diesel fuel cup.
Official kubota manual makes it appear to be lo ated underneath the deck under the brake pedals.
But kubota text connected to the very rear of the engine.
I just need am actual PHOTO or clear diagram that shows location. Thanks
7,262
The hydrsulic pump on most Kubota tractors is mounted on the upper right side of the engine. Its a standard gear pump with a very recognizable shape and size. Based on your post I suggest you enlist the aid of someone better versed in hydraulics.
7,262
Here is a screen shot from the WSM. Download a free copy from kubotabooks.com
3,879
2,399
Thats usable,
I think the WSM on kubotabooks is for a Scottish version gear transmission. The location will be the same, but if you have a hydrostatic transmission you may have a duplex pump or something else. You may have more than one filter.
Is your tractor HST? Do the loader and 3ph work correctly?
thetomtom
L3400
Jan 27, 2026
Usa
All I find is my factory user manual that came with tractor and an exploded parts diagram of the engine
thetomtom
L3400
Jan 27, 2026
Usa
At moment nothing hydraulic is working. When I raise the enginecrpm with the handle past 1,000 I get a raspy whiney sound that the last actual tractor repair person said was air or frozen moisture in the pump
7,262
11,077
I have sent him the right WSM.
If anyone else wants it just ask.
thetomtom
L3400
Jan 27, 2026
Usa
Finally got the closest dealer to call me back . To him the description is either not enough in his own words 'not enough hydraulic oil in the tractor' or the 'pump is shot'.
Got lectured about using correct hydraulic OIL from kubota. And he's the only place to get kubota branded or equivalent.
I did not change the fluids the last time it was done. I see online that using generic can kill transmission seals. But I know the first time we changed the hydraulic fluid we used a big 5 gallon bucket of traveler brand
7,262
Your dealer is clueless. The problem is not caused by a non-Kubota oil. Your tractor will be just fine using any decent quality UTTO.
Find someone that can actually diagnose the problem.
