L2550 3 point hitch won't lift any weight
Lost_Jeep
L2550DT w/ BF400G FEL & L4530B backhoe
Jan 9, 2026
22
NJ
My L2550 3 point hitch doesn't want to lift any weight. It will go up (slowly) to full height with no weight on it. With weight (my scraper blade) it only goes up a couple inches, if i lift the scraper blade manually, it'll hold in place (and stay in place if I stand on it). Let it sit overnight and it didn't noticeably drift down.
The tractor is newer to me, I recently had it split to replace the clutch. This is the first time I've put an implement on the back, and discovered the weak 3 point. I did confirm I have the lines off the hydraulic block connected correctly. Tractor has an FEL, that works and will lift the front, so I have pressure from the pump. Fluid was replaced when i did the clutch, and the level is good. I checked and adjusted the position control rod (no change). Removed and looked over the relief valve under the seat (looked fine, wasn't dirty or rusty). Confirmed FEL hydraulic lines are oriented correctly (ie power beyond line is connected correctly). I disconnected the FEL lines and moved the selector on the hydraulic block, no change.
  • Sad
Lost_Jeep
Jan 9, 2026
22
NJ
If it has the draft control option make sure its disabled.
It only has the 1 lever, so I'm assuming no draft control. I also played with the lowering speed knob, that does what it's supposed to, but didn't help with the arms not lifting.
7,314
Time to do a little trouble shooting. The lowering speed valve has no role in this
The loader works so you have hydraulic flow and pressure up front. Start there and follow the neutral circuit rearward until flow and pressure disappears.
Do you have rear remotes? If so check for pressure there and make sure all valves are in neutral. If any one of them is shifted out of neutral it will block the 3pt.
11,150
Look at the feedback linkage:
Lost_Jeep
Jan 9, 2026
22
NJ
I don't have rear remotes, or anything additional tied to the hydraulics (beyond the FEL).
I did check and adjust the feedback lever / position control rod already. That seems to work as I can limit/adjust the max lift height (with no weight on the arms).
7,314
Post a picture of the block and loader connections.
Disconnect loader PB hose at outlet block and vetify flow with loader valve in neutral.
If you have flow at PB hose reconnect that hose, disconnect hard lune going to 3pt, and vrrify flow and test pressure at outlet block.
Lost_Jeep
Jan 9, 2026
22
NJ
Loader is a Kubota BF400G, loader valve has 7 hoses, 3 connect to the block.
Unfortunately, I don't have a suitable gauge to check the hydraulic pressure, but I can disconnect lines and check for flow. I can see how much flow comes out of the hard line that feeds 3 pt off the block.
7,314
If you mean at the flanged connection under the seat that can be messy. Before you do that check for flow out the loader power beyond hose - loader valve in neutral and engine around 1500 RPM.
Unfortunately I am not familiar with that block. Do you have a picture from the owners manual showing the layout? Maybe NIW can help with that.
Lost_Jeep
Jan 9, 2026
22
NJ
I meant the block outlet that feeds the hard line that goes back to the 3 point, but I can do the same thing with the Power Beyond line coming back to the block.
11,150
Super simple and quick test.
Turn the slot on the side, this will direct flow to only the three point bypassing any of the loader connections.
If the three point starts to work then you have a quick disconnect issue.
3,117
He said he tried that (“I disconnected the FEL lines and moved the selector on the hydraulic block, no change.”) but I don’t see any evidence of that being turned in the last few days. It looks like that slot has not been touched in quite some time!
11,150
Yea that selector has not been turned in quite some time.
Lost_Jeep
Jan 9, 2026
22
NJ
Despite the heavy layer of rust protection (oily grime), that's the selector I moved. When up (turned clockwise), the FEL doesn't work, and the 3 point shows the same symptoms (moves slow & won't lift any weight), when down (counter clockwise), the FEL works.
7,314
We could guess for weeks on end. You need to invest $20 for a pressure gauge and get some empirical measurements.
Lost_Jeep
Jan 9, 2026
22
NJ
I ordered a hydraulic pressure gauge, going to be a few days before it gets here.
3,117
You will probably need some adapters and a disconnect half to get the gauge connected to the tractor???
And sorry about that screw looking untouched statement. The grime just looks like normal oil/dirt sludge not something that can survive a screwdriver twist!
11,150
Highly unlikely a pressure issue as the loader works.
More likely a control linkage or three point valve issue.
You don't have the three point speed adjustment set to one extreme or the other do you?
