Hello, good evening. I have a problem after disassembling my rotary tiller due to a broken bearing on the shaft where the tines are mounted. The issue is that after removing the broken bearing races inside, I realized the inner part is inside the shaft and I can't remove it at all. I've removed all the seals and cleaned up the damaged parts, but it's impossible. Is it designed to require cutting the shaft to remove the bearings and chain?
