Putting the cart before the horse…..Three Phase power question???????
4,158
OK fellas, I finally “stepped up to the plate” and bought a Bridgeport. I still have to get it in the basement, but when I do, I have to power it; So I am trying to “think ahead” a little and formulate a “plan of attack”.
Like most people, I obviously have single phase power, so I am going to have to “make my own” 3 phase power to run it.
I have done some initial investigating on my options, which I believe to be the following.
A) Use a Digital Phase converter.
B) Use a Variable Frequency Drive.
C) Use a single phase, 220 volt motor to turn a 3 phase motor, thus creating “actual” 3 phase power.
I have some “very basic” understandings of these options, but would like some opinions/reasons from y’all.
I am curreently leaning towards a VFD.
My reasoning is that a VFD will allow for ‘speed control”; So I can put the machine in “fast gear” and control the motor speed (i.e. slow it down) with the VFD, and they seem very reasonably priced.
My current understanding is that a Digital Phase Converter will not allow for “speed control” , and option “C” seems unnecessarily complicated, and expensive, and will also not allow for “speed control".
Is my reasoning sound?
I am open to other suggestions/ideas/options as well.
ken erickson
Nov 21, 2010
1,300
2,280
Waupaca Wisconsin
I ran a 1HP step pulley Bridgeport mill for a decade with a static phase converter in my Gunsmithing business with good results. My understanding is you will lose about 1/3 of the rated horse power. For my work at the time not an issue.
I currently have a static phase converter on my Harig Super 6-12 surface grinder with equally good results.
I have 3 VFD single phase converters running various knife making grinders. Two 2 x 72 belt grinders and a 8 inch disk grinder.
I WISH I would have had a VFD on the Bridgeport.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
455
442
Amsterdam, NY
Check the motor specs that comes with the unit. Do a search on "VFD motor compatibility".
Read this...
or this
2,417
Notice that @ken erickson says “3 VFD single phase converters” to get from single phase to shift the phases 120 degrees from each other. I think the converters must be able to communicate with each other to know what they are doing. That might mean they all need to be same brand?
I would recommend the VFD route.
ken erickson
Nov 21, 2010
1,300
2,280
Waupaca Wisconsin
Sorry guys! My statement "3 VFD single phase converters" is clear as mud.
Besides my static phase converter running the surface grinder with 3 phase motor I should have said I have 3 single phase VFD's running my grinders which are all single phase machines.
2,417
Sorry for my misunderstanding of your comment and my lack of understanding about the VFDs creation of the third phase.
Here is a link to a VFD being used on a Bridgeport mill so presumably pretty close to what @Runs With Scissors is thinking.
This is another discussion about the subject in general
Hugo Habicht
G1900
Jun 24, 2024
910
1,284
Ireland
I had the same problem with my lathe. The motor was wired for 400V three phase star configuration and I changed that to delta, making it 230V three phase. I use Toshiba inverters for the conversion from single phase 230V to 230V three phase. I am not using variable frequency but only the soft start (programmable) that I also use on the hydraulic pump of the pillar lift. I simply have the on/off function and the speed change is using the various gears.
3,932
2,583
Since you are putting the machine in your basement get a VFD, much quieter and cheaper.
If you are planning on more than one machine the digital phase inverter might be in budget.
GrumpyFarmer
4,352
Congratulations…that is one of those pieces machinery I’ve dreamt about but just not ready to start another hobby…it’s on the list though. Congratulations. Based on your write ups, I think you will be amazed how long you lived without it. At least I hope you enjoy it. 🍻
Now most importantly, I read ‘basement’, correct? ( I am aware you have other machinery in basement. )That’s maybe most interesting part to me. Is this being done without any legal intervention? If so I’d like to ask if you are currently taking on new mentees / apprentices? I’d like to be put on the wait list.
I hope there will be a write up about move in day.
5,739
Static phase converters suck.
A simple VFD works we if you only need to power one machine with one motor. I dont see that in your future.
Knowing your situation I would strongly recommend a DIY rotary phase converter. Cheap, easy to build, provides near POCO quality 3 phase, and capable of powering multiple machines and motors. My entire shop runs off a single 10HP RPC thats feeding a 3P panel
Cape Cod
BX23S
Oct 23, 2024
Central MA
Two options
I bought a digital phase converter 20 years ago.
Set it up in my shop wired the output to a 3 phase panel.
Wired my whole 3 phase shop to the panel .
I have moved twice since then and it all came with me.
I have had zero problem with this setup.
It comes with a price though. 20HP converter in 2005 was $6000.00
I was running 2 CNC machining centers, compressor, grinder, lathe etc.
If this is going to be your only need for 3 phase....
eliminate the need.
Yooper
3901 LA525
May 31, 2015
1,667
815
NE Wisconsin
VFD with variable speed and don’t look back! Also make sure it has reversing capabilities for tapping. When purchasing, double the size of the VFD when using it for phase converting. IOW, if your mill has a 1-1/2 hp motor you need a VFD rated for 3 hp.
5,739
A simple VFD if you only need to power one machine with one motor.
Knowing your situatiin I would strongly recconend a DIY rotary phase converter. Cheap, easy to build and capable of powerung multipke machines and motors.
This is 20 years ago when it was first built for the "new" Cincinatti. Its been expanded to include circuits for two lathes, a horizontal bandsaw, and a cyindrical grinder. Still room to grow.
5,739
BTW - your understanding of C is waaaay off the mark.
Kennyd4110
Vendor Member
Sep 7, 2013
1,408
726
Westminster, MD
www.boltonhooks.com
When used as a phase converter most VFDs have to be derated by at least 25% and 50% is safer.
Sorry, that is an internet myth, 100% not true for VFD's.
I have three of them...not an 'expert' by any means, but plenty of experience with them.
ETA: The ONLY time you need to rerate them is if you are NOT feeding them to 240 volts (single phase of course) on the input. Otherwise, for up to three horsepower motors you math the VFD rating to the motor.
