Putting the cart before the horse…..Three Phase power question???????
4,152
OK fellas, I finally “stepped up to the plate” and bought a Bridgeport. I still have to get it in the basement, but when I do, I have to power it; So I am trying to “think ahead” a little and formulate a “plan of attack”.
Like most people, I obviously have single phase power, so I am going to have to “make my own” 3 phase power to run it.
I have done some initial investigating on my options, which I believe to be the following.
A) Use a Digital Phase converter.
B) Use a Variable Frequency Drive.
C) Use a single phase, 220 volt motor to turn a 3 phase motor, thus creating “actual” 3 phase power.
I have some “very basic” understandings of these options, but would like some opinions/reasons from y’all.
I am curreently leaning towards a VFD.
My reasoning is that a VFD will allow for ‘speed control”; So I can put the machine in “fast gear” and control the motor speed (i.e. slow it down) with the VFD, and they seem very reasonably priced.
My current understanding is that a Digital Phase Converter will not allow for “speed control” , and option “C” seems unnecessarily complicated, and expensive, and will also not allow for “speed control".
Is my reasoning sound?
I am open to other suggestions/ideas/options as well.
ken erickson
Nov 21, 2010
1,298
2,277
Waupaca Wisconsin
I ran a 1HP step pulley Bridgeport mill for a decade with a static phase converter in my Gunsmithing business with good results. My understanding is you will lose about 1/3 of the rated horse power. For my work at the time not an issue.
I currently have a static phase converter on my Harig Super 6-12 surface grinder with equally good results.
I have 3 VFD single phase converters running various knife making grinders. Two 2 x 72 belt grinders and a 8 inch disk grinder.
I WISH I would have had a VFD on the Bridgeport.
Bee-Positive
Nov 16, 2022
451
436
Amsterdam, NY
Check the motor specs that comes with the unit. Do a search on "VFD motor compatibility".
Read this...
or this
2,411
Notice that @ken erickson says “3 VFD single phase converters” to get from single phase to shift the phases 120 degrees from each other. I think the converters must be able to communicate with each other to know what they are doing. That might mean they all need to be same brand?
I would recommend the VFD route.
ken erickson
Nov 21, 2010
1,298
2,277
Waupaca Wisconsin
Sorry guys! My statement "3 VFD single phase converters" is clear as mud.
Besides my static phase converter running the surface grinder with 3 phase motor I should have said I have 3 single phase VFD's running my grinders which are all single phase machines.
2,411
Sorry for my misunderstanding of your comment and my lack of understanding about the VFDs creation of the third phase.
Here is a link to a VFD being used on a Bridgeport mill so presumably pretty close to what @Runs With Scissors is thinking.
This is another discussion about the subject in general
Hugo Habicht
G1900
Jun 24, 2024
898
1,270
Ireland
I had the same problem with my lathe. The motor was wired for 400V three phase star configuration and I changed that to delta, making it 230V three phase. I use Toshiba inverters for the conversion from single phase 230V to 230V three phase. I am not using variable frequency but only the soft start (programmable) that I also use on the hydraulic pump of the pillar lift. I simply have the on/off function and the speed change is using the various gears.
