How to Jam New Seal on L3170 Front Axle?
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
I got around to replacing the oil seal on my L3710's front axle today. It's not a bad job, EXCEPT for removing the metal part of the old seal and installing the new one. The metal ring is extremely tight on the axle, and it has rubber inside it to make the friction worse.
A guy on the web said to heat it for 30 seconds to 1 minute with a torch to make it slip off. This works, except it takes longer than he said.
Now I have the old part off. I am cleaning the axle to make sure no burned rubber messes up the new seal.
What is the best way to jam the new seal on there? The rubber part is no problem, but the part with a metal ring is very hard to push on. A Youtube dude says lube doesn't help.
I pushed it on a short distance just to see what it's like, but I am not willing to continue until I have better information, because getting it out if I screw it up will not be fun.
I'm thinking I should try to find a piece of pipe that fits the ring and use it to push the ring on the hydraulic press. I would think even PVC would work.
It turned out the inner bearing was wiped out. The cage was broken. Two new bearings will go in as soon as the seal is on.
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
I was able to bop the seal onto the hub using a short PVC fitting to push it, so that's finished.
Now I'm confused about the torque on the screws and nuts on the axle cover. Kubota calls its parts certain things in its catalog and completely different things in the WSM.
The WSM says to torque the axle flange mounting screws and nuts to 17.4 to 20.2 Ft.lbs. It says to torque the axle flange mounting stud bolt (singular) to 8.7 to 11.5.
There are two nuts mounted on studs, and the rest of the fasteners are screws. I don't see any "mounting stud bolt," and I don't see any fastener that is only used once. I guess Kubota had its usual translation problems.
3,285
1,700
The stud itself is torqued to 11 ft lbs, but when you put the lock washer and nut on it, the nut torques to 20 ft lbs.
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
Thank you. That's the opposite of what I guessed after studying the manual.
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
Thanks. I called them screws. It's my understanding that bolts to through smooth assemblies into nuts, and screws go into threaded assemblies.
It looks like I did this wrong. Apparently I have to use two nuts on each stud to torque it, remove the nuts without disturbing the studs, and then put the nuts on.
9,307
Screws engage a material without threads cut, cast or embedded into material.
Bolts engage a material with threads.
There are exceptions to this "rule" one of which is self tapping bolts.
You don't call then head screws they are head bolts
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
Let's quote the authoritative source so this rabbit hole gets closed off permanently.
From the American Society of Mechanical Engineers:
The ASME B18.2.1 standard defines a bolt as an externally threaded fastener meant for insertion through holes and typically tightened with a nut. It defines a screw as an externally threaded fastener capable of mating with or forming threads and tightened by torquing the head. This distinction has been recognized in a U.S. court
9,307
Great now we have a US court ruling on the distinction... I throw in the towel! 😣
4,115
Bolt
Screw….
Now, the real question…….Since I am not a “Biologist” ;) …...Male or Female????
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
259
156
NH
And then there is the machine screw. What gender would this be?
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
Personally, I would not name my son after a self-destructive drunk or a guy who couldn't sing.
4,115
Me neither, but I might name him after one of the “greatest press’s made”……..
Tough call………... (y) ;)
3,655
Just to be more-accurate…..(since courts have become political)…. the name of the person without taste is “Dylan”….. a person who practices masquerade.
”Bud-Light” is not beer. It is fizzy-pop, masquerading as beer.
Hopefully we are all now weiser.
