Seal Kits for BH75 backhoe
jcheil67
L3400, BH75 backhoe, LA463 Loader
Oct 19, 2025
9
Central Florida
I've been trying to find AFTERMARKET cylinder seal kits for for my BH75 (Serial# 12168) backhoe attachment on my L3400.
The price the OEM wants for the seal kits is an absolute joke. I mean seriously, $200+ for seals? Even the companies that "discount' them to $100+ is still a ridiculous price IMO.
I was able to find aftermarket seals for the swing ($25 each) but none for the other cylinders. Here are the part number that I need. Has anyone sourced aftermarket, reasonably priced seal kits?
Boom 7k501-22300 (qty 1)
Dipper 7k501-32310 (qty 1)
Bucket 7k501-43300 (qty 1)
Stabilizers 7k501-52300 (qty 2)
Thanks in advance.
11,278
Go to a local hydraulic cylinder repair place they should be able match up the seals.
3,990
2,470
I was hoping to order online. It's 2+ hours to my nearest hydraulic shop and I would have to bring everything to them. So basically nearly a whole day would be shot.
Your other option is to measure them yourself and order from a seals part place. But you'll have to have them apart to measure. Part numbers won't do you any good.
jcheil67
Oct 19, 2025
9
Central Florida
I do have them all apart already. And I do have all the necessary measuring tools to measure them.
But again, I was just hoping that someone has already been through this expedition and found aftermarket seal kits online somewhere and could send me a link.
If I don't hear from anyone in a couple weeks I'll probably resort to measuring them.
jcheil67
Oct 19, 2025
9
Central Florida
Bump
Cody45320
B3030, BH75
Nov 5, 2025
VA
I agree, $250+ for 1 set for a swing seals. CRAZY high. Someone has to know a online place that has aftermarket OEM type seals.
3,990
2,470
/Tweak on
OK OP, two weeks is up. What have you done? Since you have the tools and the cylinders disassembled, I really don't see much involved in measuring a few grooves and selecting parts from an on-line catalog.
/Tweak off
I am interested in what you decided.
jcheil67
Oct 19, 2025
9
Central Florida
/Tweak on
/Tweak off
So. I am still on my cruise until Saturday. Next week, I am going to town on Wed. I plan to bring the pistons and glands to the hydraulics place and see if they can source them. I have had good luck with them in the past making custom hydraulic stuff for me. This will be the first time I'll be utilizing them for any kind of a cylinder reseal or parts.
I will definitely post any part numbers or the specific sizes of each when they give them to me.
3,990
2,470
Sounds good. My hydraulic shop charges $100 each, and will usually do it in a couple of hours or less if I get there fairly early, since I'm from out of town (20 miles 🙂).
jcheil67
Oct 19, 2025
9
Central Florida
Hey just an update for everyone.
I brought the Pistons and glands to my local, 2-hour drive each way, hydraulic dealer.
They measured everything and ordered everything I needed and installed all of the new seals on all seven pistons and all seven glands.
Total was $710. I consider that to be very acceptable considering Kubota wants $250 for each seal kit.
When I pick up the parts in about a week, they said they left a sheet showing the dimensions of each one which I will post here when I get it.
I'll also post their phone number in case someone needs a good hydraulic dealer and don't have one locally. They've always been good to me.
Jass
L2501
Dec 26, 2016
27
Auburn,ca,usa
German bliss equipment (germanbliss.com) has the seal kits for a bh75 for $40 each, part #'s 1038997 and 1038998.
I have a bh7500-1 backhoe and just order seal kits for it but they are a little different from bh75 I guess and cost about $75 each.
jcheil67
Oct 19, 2025
9
Central Florida
Well that doesn't make sense because there are five different size seal kits needed for seven cylinders total.
So I'm not sure what part numbers those are that you referenced above?
Jass
L2501
Dec 26, 2016
27
Auburn,ca,usa
From their website there are six hydraulic cylinders each with same diameter (2.48 x 1.26) but different lengths that take the same seal kit pt# 1038997 and one with diameter 1.97 x 1.18 that takes seal kit pt# 1038998.
But, maybe their website is wrong? Did you go to the website and check? They also have a phone number you could call to check as well.
jcheil67
Oct 19, 2025
9
Central Florida
I went to that site and none of the part#'s you posted above show up on a site search. Maybe you could post a link? But, the more I look at that site you posted the more I realize that the BH75 they are selling is NOT the Kubota factory BH75. The one they are selling looks like a child's toy compared to the size of the factory Kubota BH75.So those seals will not fit the real BH75.
Also, the cylinders on the real BH75, none of them are the same dimensions except the 2 swing cylinders and the 2 leg cylinders. And for clarification, the swing cylinder size is different than the leg cylinder size but both legs are the same size and both swing are the same.
The other 3 cylinders are totally different dimensions of both the tube diameters and rod diameters. Although they are somewhat close (1/4" to 3/4" differences). I attached pictures below to show the difference. The color picture is the small one from the site you linked above, the B&W one is the factory Kubota BH75. You can tell they are WAYdifferent.
But thank you for trying. Again, when I pick them up I will post all the seal dimensions here forthe next person.
Vlach7
L47 305DT JD500C
Dec 16, 2021
453
330
Frazier Park Ca
They wanted $500 for my L47 FEL tilt rams, went to the hydraulic shop got 2 sets and they broke the rams open for me, I could not break it with a 3' pipe wrench, for $400.
jcheil67
Oct 19, 2025
9
Central Florida
Yeah mine were almost 20 years old and they were very difficult to open up but since I knew I was replacing all of the seals anyways a little bit of heat from the oxacetylene torch broke everything free and then a 24" pipe wrench getting hit with a 5 lb sledge a few times broke All of them free.
And yeah that sounds about typical labor rates and seal rates. I had guessed it was going to be about $100 each.
In my case I absolutely could have done the labor myself but they've always been good to me and I figured letting them do the labor would also guarantee that the parts they are ordering are the exact fit.
