B1700 Kubota Lawn Mower
gene
lastec 3372/B1700/B2150
Apr 24, 2013
25
ohio
My Lastec 3372 zero turn lawn mower is down and I'm using a Kubota B1700 with a 60" mower deck as a backup. The bumpy ride I'm experiencing is terrible when compared to my Lastec. I mow about four acres and am completely worn out by the time I'm finished mowing. Will my ride improve considerably if I reduce the air pressure in all four turf tires? Any suggestions will be appreciated.
3,490
2,069
Probably, how much is in them now? Also, does it have a loader, if so, removing it will help a lot.
9,480
A better suspension seat assembly will do it.
On the tires, don't do too low or you'll ruin the tire.
gene
Apr 24, 2013
25
ohio
Sorry for the late reply. I had go over to Walmart to buy a couple of tire gauges. It shows only 10psi in the rear tires and 15psi in the front tires, but they seem to have more psi than that. That's why I bought new gauges.
gene
Apr 24, 2013
25
ohio
Also, the B1700 does not have a front end loader.
3,490
2,069
I think you could safely drop those a couple of psi front and back.
