Foundation Drainage Maintenance Question
Bee-Positive
Nov 16, 2022
1,184
1,088
Amsterdam, NY
Built a 2-story ranch in 2007. Has 4” drain pipe around the perimeter with capped risers (cleanouts?) to above grade on 3 out of 4 corners. In the west corner 4” solid pipe runs from the footing out 165’ to daylight, so no sump pump is needed.
Weed-wacking around the outlet last week I noticed some build up in the mouth of the pipe. Reached down to clear it and it’s like rock. Got my longest pry bar and mini-sledge and managed to chip some of it out (picture). Very hard stuff - probably hardened minerals/silt. Wouldn’t be surprised if there weren’t critters in there to boot since no end cap on the outlet.
I’m worried that it will eventually plug the drain since it’ already 1/3 plus at the outlet. Not wanting to wait until I get a wet basement I thought I’d better address the issue now.
Power-jet, roto-rooter, dig it up? Would rather not dig up hard clay and shale if I don’t have too, 7’ - 8’ deep at the house.
Has anyone here had similar issues / what did you do / what did it cost?
TIA, AOW
165' drainage run and mineral build up
NorthwoodsLife
Oct 15, 2021
1,410
1,475
Wisconsin
Hire a good plumber that can run a camera.
Since there's clean outs at one end and daylighted the other they could go both ways.
They are ways, and solvents to clear out concrete. So maybe something to dissolve hardened mineral deposits is available.
The good news is, it is not under slab or even a building. So repair will not be bad if they have to replace some drainline.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
Sure would be good to know what it is for starters. Also where it originated. It would be disturbing if it was starting to fill the foundation drains. With that run it would be possible to run a camera through it. Since you had to chop it out, I'm doubting that a water jet would work.
jaxs
B1750HST
Jun 22, 2023
1,107
830
Do you by chance have an enemy that deals in concrete? :cautious:
Bee-Positive
Nov 16, 2022
1,184
1,088
Amsterdam, NY
Pretty sure its mostly mineral deposits. We have extremely hard water here.
There are under ground springs coming off the hill, the yard doesn't dry out until mid-June most years. the drain will run even in times of little to no rain.
#40Fan
656
484
Can you put the piece in a bucket of water and see if it will dissolve?
11,246
lime and Calcium
I wouldn't do anything about it.
Any of the main line cleaners could clean it right out.
CLR will also break it down and clean it out.
But it's risky because if it leaches out into the foundation it could damage it.
You can't normally scope corrugated drain pipe.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
350
536
NC
How deep from the cleanouts to the drain pipe? A cheap endoscope/borescope from Amazon that works with your cell phone could at least show the condition of the drain pipe at each cleanout without spending the money to scope the whole pipe. If you've got deposits at each cleanout, you can assume the whole pipe is the same way.
They're also useful tools for all kinds of other things from inspecting engine cylinder walls to entertaining kids/grandkids.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,479
671
Richmond, Virginia
lime and Calcium
I finally discovered a trick for running a scope or clean out brush in corrugated.. Take a small, solid ball (golf balls often work). Bore a hole through it so the camera or tool will fit tight.. Now the camera or tool will slide in (and not snag) over the corrugations easy. The only down side is if there is a blockage but.... Based on how far you got will give a great indicator of where it is.
4,145
2,836
TIA, AOW
View attachment 159931 View attachment 159932 View attachment 159933
Looks like someone has the water softener draining into the weeping tiles?
7,017
as others posted...camera, then jetter if needed.
Blue2Orange
Apr 3, 2025
435
303
Bayview Township
Maybe an inexpensive and relatively harm free option for removing calcium, magnesium if that is what your "concrete" is.. Citric acid solution. Inexpensive crystals/powder available at major retailers. Try testing a chunk of your "concrete" before purchasing an industrial size amount. Use to use it for descaling boiler heating elements in espresso machines. Just requires a bit of time to dissolve build up. If any copper plumbing? Beware that citric acid will strip the oxidized protective patina off of it. Blue green water is a hint. IIRC, CRL has lactic acid and ????
6,323
for sure find out what WILL dissolve it , NOW.... though you didn't say how long it took to get that plugged up.
once you know what will get rid of it, maybe setup a tank,[pump, timer to add the 'dissolver' on a regular basis.
wait too long and that 165' run of pipe WILL have to be dug up and replaced, maybe with 6" or larger.
Bee-Positive
Nov 16, 2022
1,184
1,088
Amsterdam, NY
Exactly!
2025 - 2007 = 18 years. I figure is I take care of it now I won't have to do it again in my life time. LOL
Definitely going to take others advice and see if it will "dissolve" with various substances. I definitely don't want to use anything hazardous, honeybees and crops all around and such.
The cleanout cap is at least 6' - 7' straight down to the foundation.
Footing drain is perforated solid PVC not corrugated. It's been 18 years and I have trouble remembering what I had for breakfast this morning and it's not even noon yet so I could be wrong. :rolleyes:
Next step is to call around, get it scoped and see what the solution will cost.
Thanks all!!!
Bmyers
May 27, 2019
3,640
4,956
Southern Illinois
White vinegar (acetic acid) can dissolve calcium and some mineral deposits.
CLR will also work (phosphoric acid) does a good job of breaking it up.
Muriatic acid (hydrochloric acid) works really well on tough deposits.
Yet, a couple of items of note. You are using a strong acid mixture. So, it can damage things and need to be aware of where the mixture is going. Also, the fumes can be harmful.
Playing with acids can be dangerous, so take the time to educate yourself and don't assume just because it is sold at the store that it must be safe to use.
Used improperly, these can be deadly.
Blue2Orange
Apr 3, 2025
435
303
Bayview Township
CLR contains lactic and gluconic acid. Maybe phosphate salt of the two acids? Household white vinegar might be very slow. If going that route you might what to purchase "agricultural" acetic acid. I use a 40-45% diluted down to ~15-20% to kill weeds. Relatively inexpensive, but at full strength you need eye and skin protection to handle safely.
If going the chemical route just test and use the lowest effective concentration.
Blue2Orange
Apr 3, 2025
435
303
Bayview Township
Op, have you found a fix?
OP, at least it is only a foundation drainage system plugged up. A diy fix if you want to vs. no choice but a contractor. One of my neighbors down the township road had a similar issue. But it was their septic drain line from house to holding tank. Poor septic tank and drain field maintenance. Prior to the county zoning keeping track and fining people. Some never spent the few dollars for inspection, pumping, and maintenance. Neighbor ended up spending thousands on a newly engineered and installed septic system.
County Zoning now keeps track of septic maintenance and fines you for every day beyond the due date for routine inspection and if needed pumping of the sludge build up in you tank for conventional drain field systems.
Bee-Positive
Nov 16, 2022
1,184
1,088
Amsterdam, NY
Haven't yet, we're in a draught right now so little to no flow. Seems to rain all around us but not here. I'll definitely get it done before winter sets in. Got several other things draining the bank account at the moment.
I've had my septic pumped a few times (last year actually) , try to do it about every 5 years at most. Just the wife and I so not too heavily used. Cost me $4K for a semi-raise septic field when we built so I know it gets expensive when neglected.
Luckily no "Big Brother" here as far as the septic is concerned. Property and school taxes are a whole nother ball game.
7,349
Does your footer drain generally run most of the time? Mine runs a couple/few days or weeks/year. Sometimes will go a year or two without flow.
Might have a bearing on how you deal with the build up. Might be for the better.
As far a Property/School Taxes - - I'm in New York also. I agree 100%
