The first thing I made for our "new" B7200 was a ROPS. I bought the tractor to build and fit a front loader, and thought it would be better to have the ROPS first, as if I built the loader first I would be tempted to use it without a ROPS. The mounting is based on pics of a bought one and it's fabricated from 12 mm steel plate. The square tube is 50x50x5.
I'm not sure I like the width as it is - might make it a little narrower and have a go at bending some rounded corners for the top.
I also think I'll reinforce the mounting by using the 4 threaded holes in the axle housing either side of the current mounts. May even add some bracing to the corners.
I also added a seatbelt that came out of an old 60 series Landcruiser that we still have sitting here collecting rust since we last drove it about 15 years ago.
Half the reason for buying a small tractor was to use it, the other half was to make things for it.
