BX2380 Mower Deck Help
BaldNCane
2022 BX2380
Jul 9, 2025
Lexington, Sc
I’m trying to find a mower deck for my BX2380. I’ve found a couple on FB and was wondering if either of these will work:
or
5,860
don't have one but think mower number -bx23 or similar should be on the tag ?
since you're in the USA, try to 'build a BX' and look at the deck options, should give you the deck models that'll fit.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
487
491
Amsterdam, NY
48" Mower deck - RCK54D-18BX
54" Mower deck - RCK54-23BX-1
60" Mower deck - RCK60B-23BX
See if they will send you a picture of the tag or type the # in a message reply.
3,495
2,086
Thank you for your replies! I’m picking up to 60” today!
I'm not familiar with these, but make sure you get all the brackets, etc. you need to hook it up. I think there's another piece of driveshaft.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
274
420
NC
There are two brackets that attach to the front of the deck and suspend it under the front of the tractor. Make sure those come with it. Even with those brackets, I think $1000 with that damaged wheel and the missing pulley covers is overpriced. I picked my 60" deck up used for $1k last year in almost pristine shape.
One more note: The decks with orange gear boxes are older versions than the ones with black gearboxes. I don't know if one is better than the other or not, but if they're the same, I'd rather have a newer deck than one 15-20 years old.
BaldNCane
2022 BX2380
Jul 9, 2025
Lexington, Sc
So, I missed some of your replies. I made a deal with the guy that he would refund me if it doesn’t fit. It turned out to be an RCK54P-23BX. We called the local dealer, but he couldn’t say one way or the other. The brackets look to be about the same. On both. We shall see…
Otherwise, that’s one expensive mistake!
Bearcatrp
Mar 28, 2023
1,049
674
Minnesota
Just bring your tractor with you and mount it there.
Bee-Positive
Nov 16, 2022
487
491
Amsterdam, NY
Here are the mower decks that will fit your BX2380. The last 2 with the "D" indicate "Drive-Over".
This image shows the front link (red) and bracket (yellow) that you MUST have to connect the mower.
All other linkage should be on the tractor. If not you're screwed and have to call the dealer. All of it should be readily available.
BaldNCane
2022 BX2380
Jul 9, 2025
Lexington, Sc
I did receive the front link. I will double check to see if my tractor has the front bracket, though. I have help to move the thing around today, so I’ll report back how it goes. Thanks for the heads up!
