Bx2750 snowblower subframe needed
Smitty906
L3130 , loader backhoe
Dec 24, 2024
Hi , Just picked up a 2750B blower and frame yesterday and what I can tell is that it has the wrong frame for my tractor.
The data tag is not legible but po said it was off a b2400.
Does anyone know the correct part # or have one for sale Michigan / Wisconsin .
Thanks Mark
Spam Bot
Windows Computer
Aug 3, 2024
179
129
Austin, Minnesota/Key West FL
Very difficult to find just the hitch for a snowblower. I have a snowblower that has been advertised for sale on Facebook Marketplace for over 2 years, but I haven't been able to sell it because I didn't have the hitch to attach to the tractor. I just bought the correct hitch for the snowblower, and it cost me $500 for a used one. Unfortunately, three pieces are missing that I will have to order through parts, as they were inadvertently left on the tractor when it was traded in. Those three parts are almost $500! Mine came from someone who removed it from a BX because they were selling the tractor for a B series and needed a different hitch for the new tractor. The dealer didn't want the hitch if the snowblower wasn't traded back with the tractor. I will be advertising both the snowblower and hitch this coming winter, and I expect them to sell quickly.
Don't forget that you also need a driveshaft, which alone costs about $450. I just searched YouTube for a video and found this one, which will help you understand what's involved in mounting the snowblower. There is one thing wrong with the video, and that is that the shaft is the last thing to be installed, not the first.
Smitty906
Dec 24, 2024
Smitty906
Dec 24, 2024
That's the info I am getting from the dealer as well. Closer to 2k for everything I need .
I was told I will need
bx2751
bx2752
bx2753
Which Hitch do you have
7,325
Thanks Mark
What tractor are you looking to hook it to?
Without that information - - I don't think anyone can advise you correctly.
You have an L3130 in your profile.....doubt that's going to work.
Like others have said - - the snowblower is a big paperweight without the proper front hitch and mid-PTO to make it work.
They can be hard to match up and find the correct front hitch and mid-PTO shaft combination.
Spam Bot
Windows Computer
Aug 3, 2024
179
129
Using Artificial Intelligence, I found this information for the L 3130 tractor:
The Kubota L3130 tractor can use Land Pride's SB10 series snow blowers and SBL25 series snow blowers. Specifically, the SB10 series comes in 51" and 64" widths, according to Kubota. The SBL25 series, which is fully hydraulic, includes models SBL2566, SBL2574, and SBL2584.
Here's a more detailed breakdown:
Then, moving on to Google, I found a discussion from 2010 on TBN (Tractor by Net) with a lot more information. I initially thought that you owned a BX tractor, and that is what I tailored my response to. I hope that this helps shed some light on what you will need for an L3130 Kubota tractor.
Smitty906
Dec 24, 2024
Smitty906
Dec 24, 2024
BX 2230 is what am looking to put this blower on , I guess I forgot to add that in the post.
7,325
Mark - I’m not 100% sure the BX2751 is the correct hitch for a BX2230.
Not saying it’s incorrect; I’m just not sure.
The BX2751 is the actual hitch/subframe. My manual references BXxx50 series and 60 series, but not 30 series.
The BX2752 and BX2753 are the mid-PTO shafts. Should be one or the other I think as they’re the same but one is longer. I have the longer BX2753 on my BX2360.
Can barely see it sticking out the back side of my hitch.
There’s also a “driveline” that connects the tractor’s mid-PTO to the hitch’s mid-PTO shaft. That’s #7 in the diagram above. Didn’t measure mine but it’s about 36” long.
Is your BX2230 equipped with a loader? If so, does the loader valve come off the tractor with the loader? If so, there might be an additional bracket that the valve mounts to.
Smitty906
Dec 24, 2024
Thanks RCW , under Kubota parts it lists attachments for 2230 and the 2750 blower but no quick hitch . Guess I will have to call dealer .
Smitty906
Dec 24, 2024
Yes the loader joystick stays with tractor , I guess I will call dealer tmrw for correct quick hitch parts # for a 2230.
7,325
Mark - that’s good.
I would try to find a used BX2751 (if you confirm it’s correct). Not much to go wrong with one.
Sometimes see them for sale. I think a few have been sold on OTT.
7,325
Here are the parts lists for the BX2752 and BX2753.
If you go that route, you’d want to buy the whole kit, not the individual parts. Just provide it for information purposes.
Has lengths for the output shafts and other useful information.
BX2752
BX2753
Smitty906
Dec 24, 2024
Thanks again
I'm going to focus on a blower that came off of a 2230 . This way I know for sure.
On another note I have a blower ready to bolt on a b2400 for sale ...lol
7,325
Thanks again
Pretty sure the BX2750A snowblower is fine for your tractor.
You need to verify, but think you’re set there.
The BX2751 front hitch I’m almost 100% sure works with your BX2750A snowblower.
According to @Spam Bot - the BX2751 is the correct hitch……..
That is the correct hitch for the BX2230. Your BX2230 is about 20 years old and is a model similar to the BX22 TLB. Here are the specifications on that tractor: https://www.tractordata.com/farm-tractors/005/3/0/5300-kubota-bx2230-attachments.html
If you can identify a hitch with the PTO kit and the driveshaft, you will be in good shape.
Spam Bot
Windows Computer
Aug 3, 2024
179
129
Don't let the letter after the model number of the snowblower trick you. Each letter designation indicates that a part in the parts list has a new part number. Most times, it is a small change. I believe that there are five different iterations of the BX2750 snowblower. The original BX2750, BX2750A, BX2750B, BX2750C, and BX2750D.
LXHobbyFM
LX2610/Deere 85
Jan 11, 2024
17
N. Illinois
Smitty, I have an extra bx frame (bare, needs full mid pto kit referenced above). No need for it so I'd let it go cheap.....will be in N Wisconsin this weekend. PM me if interested.
Smitty906
Dec 24, 2024
So I will share a little info regarding the 2200 and 2230 BX models.
They do in fact take the bx2751 hitch , the bx2750 (a-d), bx5450 , and bx5455 are all designed to work with this hitch . As well as bx2763 and tg2754 front blades and front mounted broom.
Hope this helps someone down the road !
