Kubota z275 blades not engaging help needed
Mauney
Kubota Z275
Jun 20, 2025
Fletcher, North Carolina, USA
While I was mowing last week, the blades suddenly stopped working and now I cannot get them to engage. I have tested the PTO switch and check wiring to the PTO clutch. I have found that the pto clutch connector ground wire is not showing ground. I ran a jumper from the pto clutch ground wire directly to ground and then the blades engaged and operated fine.
How can I check to see why there is not ground at the pto clutch? Any help is appreciated. Also, does anyone know of a kubota z725 service manual available as pdf?
5,291
How can I check to see why there is not ground at the pto clutch? Any help is appreciated. Also, does anyone know of a kubota z275 service manual available as pdf?
Seems to me you have found and fixed the problrm.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
288
283
Amsterdam, NY
Yup - what Dan said in post #2 above.
Follow the ground wire to where it connects to the frame. Sounds like it's worn, cracked, etc. if it just stopped suddenly. Replace as necessary. If cable is good remove and clean the connections, reattach.
Quick search showed a WSM on eBay. The mowers are still made by Kubota so I would imagine they are out there to be had.
5,291
Quick search showed a WSM on eBay. The movers are still made by Kubota so I would imagine they are out there to be had.
Actually, in post #2 i declared the problem identified and fixed 😀
3,186
1,604
Wiring schematics are in "Electrical- Wiring Diagrams" under "Sticky Threads."
