Six more HP from the same engine?
8,579
Now you’re just being argumentive. The “short block” is not the same base-engine as a “long block”. The short block is only the block, crank, and lower-end…..the Long block offers all kinds of differences depending upon which heads are installed.
Very simply, a completely assembled base engine can have its top RPM, fuel-system, and/oir induction systems modified to produce different outputs.
I'm well aware as to the differences between a short block and long block, and also aware of the different ways that engines can achieve power. You can call a turbo an accessory all day long but it doesn't mean it's an accurate description.
What's interesting is that you're arguing the case for another member who has already stated that they weren't aware of the differences between Ford's 6.7 and 6.7 HO engines when they stated that they were the same engine. They were ok with learning something new. Arguing as to what you "think" the other member meant though, even after they had replied to my post seems to me that you're the one being argumentative. No shocker there though.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,542
2,007
Western MT
For a lot of engines, you can get a lot more power with tuning. However, there are other options including turbo or not, and increasing the boost pressure if it's a turbo.
Car manufacturers have started selling OEM tunes to have more HP for gasoline engines as well.
At some point, maybe we'll have the freedom that Canadians have regarding tuning.
jyoutz
Jan 14, 2019
3,351
2,394
Edgewood, New Mexico
Everyone I know that messes with diesel tuning on their truck ends up with burnt pistons of some other engine failure down the road. Engine components are a system designed to work with the designed tuning.
JasonW
431
217
Al
Just for reference what engines are you talking about?
With any tuning or modifications to add power you need to monitor EGT temps. Keep your foot to the floor uphill towing and something will melt. I’ve had modified diesels for over a decade and never had an issue.
Some tuning on electronically controlled diesels will defuel if EGTs reach a certain threshold through the ECU. Even factory tuning.
whatsupdoc
L3302
Jul 9, 2024
80
The point I was trying to make is that on The L3302 and The L3902 there appears
to be zero engine differences, every part is the same including the engine CPU
so you are paying a few thousand dollars for an injector dwell timing difference.
JasonW
431
217
Al
Basically yes. More HP more $$
jyoutz
Jan 14, 2019
3,351
2,394
Many of the Dodge Cummins and Ford Powerstrokes.
jimh406
Jan 29, 2021
2,542
2,007
Western MT
Tuners usually come with several tunes from mild to wild. Some tunes focus on emissions/mpg and make the trucks more reliable.
On the other hand, the other tunes can cause damage, but most of those people would destroy an untuned truck.
3,349
I”m not arguing a case for any other person. I was discussing the difference between Your definition of “basic-engine” (which appears to include any/all accys)…and what I believe to be the industry-standard basic-engine which does not.
8,579
Read what @John D 2 stated:
"My 2020 F250 Powerstroke diesel engine is rated at 475 HP/1050 Torque.
There is an option for a high out version rated at 500 HP/1200Torque.
Exact same engine just tuned differently."
I was simply making the point that it's not just a different program in the ECU that differentiates what shows up under the hood when you buy a 6.7L Ford Super Duty or a 6.7L HO Super Duty (which I have). The differences I know about are the water cooled turbo and exhaust manifold. There could well be other differences that the masses (myself included) are not aware of, and that Ford engineers or technicians know about.
This is different to comparing an M6060 and M7060 where the only difference is the program in the ECU. I asked Reimer Tuning why they don't offer a program for the M6060 that makes it perform like an M7060 and their answer is that they could, but that they simply follow Kubota's approach of delineating between models i.e. they add 12hp to the factory base hp.
We can argue all day long as to what anyone means when they say "exact same engine", but it doesn't add anything but noise to this thread. To me, if you have to swap out parts in order to match performance then it's not the "exact same engine". You have your own definition, I have mine. Let's move on.
3,349
You may wish to “move on” and I’m not particularly trying to avoid doing so… but I think communication is important.
I think you were thinking of an engine “Installation” when you read “exact same engine”.
My first response was delineating the difference between the base engine and the “ engine-installation” …which would include accessories… which you evidently did not think of as separate components.
I was trying to be helpful so that we could discuss subjects accurately …. and that would require we be using the same vocabulary. That is all I meant.
I’ll leave the subject alone now.
Kind regards,
gh
