Late 70's L285 gauges
JD Deer& Fowl
L285 tractor V1500 A
May 30, 2025
Idaho
I scanned the topics and didn't see a thread about gauges for older units. Recently purchased a L285 and the tachometer seems to be fairly accurate and working, but the temp gauge IS NOT. Being as old as it is and Positive ground, I am not finding much on the 2nd hand market or even for new. I would like suggestions for gauges or recommendations on maybe switching it to Negative ground, whereby I could then use aftermarket gauges for oil pressure and ammeter.
Thank you,
Hugo Habicht
G1900
Jun 24, 2024
1,070
1,553
Ireland
Hello,
could you post a picture of the gauge?
I assume you have checked that the sensor is working correctly and the cables are good.
What I did in the past is using a more modern gauge and transferring the mechanical insides into the old housing and using the old needle.
2,541
You can get the gauge from the dealer. Messicks shows it is around $110
There may be a change in part number for a serial number break and there are a couple of different models so the part number I looked at might be incorrect but it was 33400-75692
9,755
Thank you,
Kubota's are not Positive ground, if the tractor is hooked up as a positive ground that would be why you having issues.
Also need to check the alternator as it will have killed it or the regulator.
