Bush hog speed .
78-79fordman
2013 m7040hd 2013 L3800HST 1969 MF135
May 21, 2013
255
Gillham Ar.
Ok have no clue were to run this m7040 . Done some to day . So look at pics and see it it looks right . It's a 1870 landpride .
There's two pics of the gauges . Do I need the pto speed at or around 540 . Or what I was in second low gear hard it sat at 540 or so for 3rd low gear .
So am I any were close to right .
Sent from my iPhone 5 using Tapatalk 2
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
The pto should be at 540 rpm's and your ground speed is whatever is comfortable for you. No matter what the ground speed is the cutter is designed to be operated at 540.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,241
157
Coyote Flats,Texas
78-79fordman
Bottom number on tach in the bottom photo of your post is pto speed. Most implements were built to built to run a 540.
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
I figure 540 for really hard cutting, pretty much whatever you think is the worst the unit is designed for. For cutting grass and light brush, I run more like 2000rpm engine speed, where my 540 mark is about 2800 engine rpm. As long as it's cutting cleanly, the blade speed is fast enough for me. Just my opinion anyway.
Saxman
L3830 ZD21
Jun 19, 2010
155
Mt. Vernon, IL
Unless conditions require it I run my L3830 at about 2200 RPM, that makes the PTO speed less than 540 but it still does a good job mowing and the engine is not screaming unnecessarily
bransdad
NC
When I bush hog I run a 10ft. offset bush hog. I pull it with a M6800. In tall grass I run it around 2000 rpm in Low 3rd. In shorter grass I run it in low 4th around 1800-2000 rpm. Very seldom do I run the PTO at 540 rpm.
WFM
L3800
Apr 5, 2013
1,470
887
Porter Maine
So If your just mowing grass or brush, 540 rpm's is not necessary ??
bransdad
NC
No you don't have to run it at 540. I actually try to stay off of 540 if I can. I was able to mow some grass today in high 1st with the motor rpm running in the range of 2000-2200. At 2200 rpm I was running 530 on the PTO.
