B6000E missing part question
Alchik
Kubota B6000E
Mar 30, 2025
South
Hi,
New to me B6000E seems to be missing a part here. Runs fine though. What is the missing part and how is it connected?
2,897
Appears to be a fuel filter
trevoroni
B6000
May 24, 2023
201
251
Yes that is where an inline fuel filter should be. There should also be a 12v fuel pump on that side below it.
And then on the other side below the tank is another filter in a spin on plastic cover.
gktilton
B7500 with Loader and MMM. Woods M4 Bush Hog, Kuhn Rototiller, 3PT Snow Blower
May 5, 2010
234
Hooksett, NH
It's been a long time since I laid hands on one but here is what I remember.
Most likely your tractor originally used an electric fuel pump and when it failed it was removed and now just uses gravity feed. A friend did that to his back in early 2000's, only time it caused an issue was uphill on steep, (really steep hills).
Hope this helps.
trevoroni
B6000
May 24, 2023
201
251
The inline fuel filter.
The Kubota part number is 12581-43012.
If you cheap out and get one from Amazon you can have mixed results like me and the plastic can melt.
Alchik
Kubota B6000E
Mar 30, 2025
South
Looks like those have been removed! I'm trying to get everything back to working original order. Very helpful! Thanks!
Thanks!
trevoroni
B6000
May 24, 2023
201
251
No problem!
I've got a couple of these old beasts and have learned a bit about them over the past few years.
If you need any more help let me know.
The owners, service and parts manual are available from the Kubota books website.
Alchik
Kubota B6000E
Mar 30, 2025
South
No problem!
I'll probably take you up on that offer! I've got some wiring issues I want to address once I get the cultivating and hilling done.
