MX5400 wheel weights
Ajmtman
Kubota MX5400
Mar 26, 2024
Minnesota
I am looking for some used wheel weights for a ‘22 Mx5400. It has 24” rims in the rear. I found some F and N weights with “W161” and “W162” on them. They are “universal “ weights. I read that the 161 goes inside of the 162. Wondering if these would fit my rims. The bolt pattern on an MX is 4 bolts, approximately 12 3/4” diameter. Has anyone tried these or know of another weight that will fit?
9,814
I have no idea if those weights would work for your MX5400. I have the factory weights on my MX so that's an option for you.
Ajmtman
Kubota MX5400
Mar 26, 2024
Minnesota
G.rid
L48 tlb, ssqa forks, manual thumb for hoe
Aug 19, 2016
207
17
Oxford, NS, Canada
Thanks for the pics. I’m just trying to avoid giving the dealer $1700 for 3 sets of weights and a bolt kit. Thinking about beet juice in the tires. I don’t like how far ballast boxes stick out the back. Don’t know which way to go.
If that ad is still up, it's only $40 bucks. As long as the diameter is small enough to fit inside the rim, you could drill new holes to match your pattern.
The cheapest I've seen them around here is $250.
GrumpyFarmer
4,440
Got it done. Weight box weights 600 lbs. empty. Old JD wheel weights slightly modified, 150 lbs each. Total cost $180.
Nice job. Looks like the box really tucks in close the machine. 👍
9,814
Can't beat the price! Looking at my MX spreadsheet and bill of sale, I paid $1,305 for three sets of wheel weights, hardware and installation.
For the MX the factory weights are 100lb each which adds up to 600lb of total weight. The M has 990lb of wheel weights.
hedgerow
392
376
Malcolm NE
Those like to be for the old A-B-G John Deere tractors. Have some of them that have been on a JD A tractor since my FIL bought it new in 1950. You have your self a cheap weight set up.
FTG-05
Jul 21, 2013
325
169
TN
Make your own out of lead, steel and concrete:
240 and 260 lbs each (difference is amount of lead) for a total of 500 lbs. Pretty much just for the cost of the concrete mix and 12 8" Gr8 bolts and nuts.
Wooddog63
In the plan- MX 6000
Mar 31, 2025
21
21
NJ - NY adirondacks
jyoutz
Jan 14, 2019
3,451
2,533
Edgewood, New Mexico
Those are nice weights - I think you convinced me of upping that game on my MX price quote from the juice of a $1000.
I’m aware of the “marine” version but always hesitant on environmental on my land should it leak or worse tire puncture.
Neither beet juice (Rimgard) or Bioballast (corn juice) have a negative environmental impact if they leaked. But leaking is very rare. You must be thinking of calcium chloride mix, which is bad both for the land and corrosive to your wheels.
9,814
I have three sets of factory wheel weights and beet juice on both tractors and would do the same if I were to ever buy another tractor. You'll almost always pay more for factory options, but I prefer to go that route for a number of reasons.
600lb of weights on the MX and liquid ballast in the tires, in combination with the rear wheels at the second to widest setting makes for a lot of traction and a very stable machine. (y)
I've owned two MX6000 tractors and would buy one again without a shadow of a doubt, so I'm sure you're going to enjoy yours.
