L3750 3 point
9,749
Give me the distance from the center of the rock shaft to the center of the lift arm pins.
Also give me a couple more pictures below the axle, it looks like your missing some other parts you will need.
DO NOT OPERATE that tractor!!!
The ROPS and the fenders are NOT ATTACHED and will simply fall off if you hit a good bump.
Cards1965
L3750DT with a BF900 loader
Apr 2, 2025
19
Southwest Missouri
I will get this pic and measurement tomorrow. Yeah, I saw they weren’t attached when I was looking to buy. I’m currently trying to get it all back together. Thanks for the warning though, I appreciate it.
9,749
You need these plates (yellow), the tab and hole on the bottom (red) is critical as it needs to line up with the pin for the lower arms, they are for the sway links.
If they don't line up with the link arm pin the dimension of the sway links change as you lift it, and that's bad.
Cards1965
Apr 2, 2025
19
Southwest Missouri
They’re actually laying right right under the PTO shaft. Why they were off, I have know idea. This was actually brought to my house on a trailer 30 miles away. I don’t know how it stayed upright.😬
Cards1965
Apr 2, 2025
19
Southwest Missouri
The measurement I’m getting is 12” from center of rock shaft to the center of the pins on the lift arms.
9,749
Arms, need 2:
Stabilizers (check chains) need 2:
OPtion: you can use 2 Rights and have adjustability on both sides:
Left lift rod:
Right Lift rod:
Top link:
You will need pins for the top link and the lift rods, easiest to get them at at local store like. Tractor supply or any farm store.
You will also need lynch pins to hold the pins and arms on.
