G1900S rear wheel studs question
Hugo Habicht
G1900
Jun 24, 2024
590
792
Ireland
Hello,
when I cut the grass at the site boundary last night, the neighbours fencing wire got caught in the wheel studs (he used strong wire, so I noticed before any damage was done).
I had a look at it today and the studs are indeed protruding the wheel, something I do not like. I believe they are the correct studs, the parts manual also shows the long thread part outside. It is a 4 wheel steer, hence the rim centre being out that far. I do not that think that they have to be that long and I am considering cutting them so that they are flush with the nuts and not sticking out any more.
Is there anything I may have overlooked that should stop me from shortening them?
Kind regards,
Hugo
Sawdust&Shavings
Apr 25, 2023
95
85
Stafford, VA
Hello,
Kind regards,
Hugo
Can you flip the studs (end to end) and have enough thread protruding to attach the wheel nuts?
2,043
What is at the center of the hub (black plastic knob)?
Is there a need to provide protection for that?
Could you just add hub caps over this area?
Hugo Habicht
G1900
Jun 24, 2024
590
792
Ireland
I thought about that. The wheel nuts would have plenty of thread and would basically be flush with the stud then which is what I want. But the studs would be protruding inside the wheel flange, so I am not sure if they would collide with anything. The king pin bearings and the wheel bearings are badly worn out, not been greased for a while, the wheels can be moved 2cm (almost 1") at the top (!), so I would not take that risk at the moment. Repairing those bushings and wheel bearings is on my to-do-list for a while and I have finally ordered the parts for that today.
The black plastic knob is a cap for the grease nipple I added. It is well inside the wheel nuts so I do not think it needs extra protection.
A hub cap would be also outside the tyre area which is not what I want. I would prefer the rubber to hit something first when it gets tight and not a stud or a hub cap.
jaxs
B1750HST
Jun 22, 2023
922
701
Don't have mower preform string trimmer duty along fence lines.
Chanceywd
Mar 26, 2021
690
612
central ny
I wonder if there is a lug bolt in that thread size that you might use instead or maybe a shorter stud is available. Don't know the thread and I am in the US so I go to places online like Rockauto or Mcmaster-Carr when needing something like that.
Bill
5,459
2,153
Bill
there is. M12-1.25, IIRC they are JD lug bolts.
i suggested the hub caps because a lot of them came with them, and they actually looked decent. Chrome. My old one had them, I should have sold the mower without the caps and gave the caps to my mom for her mower.
another option, trim the fence lines with liquid weed eater.
Hugo Habicht
G1900
Jun 24, 2024
590
792
Ireland
The thread is actually M10x1.25.
I am doing rear axle repairs at the moment, so I have everything apart. There is enough clearance behind the wheel hub, so I will simply turn the studs around with the long end pointing inwards. That saves me cutting them off; I could not find shorter studs with that thread.
Sawdust&Shavings
Apr 25, 2023
95
85
Stafford, VA
Hugo Habicht
G1900
Jun 24, 2024
590
792
Ireland
So here the result: I did turn the studs around, as Sawdust&Shavings had suggested. I also put counter nuts on the back so that the studs won't come out when taking the wheel nuts off.
There is plenty of clearance at the back as you can see here:
Wheel nuts flush with the studs on the outside now, looks great.
And everything inside the tyre now, I rather hit something with rubber than with steel when things get a bit tight :)
