Glow Plug Cord Broke! M4050
Airgator
Kubota M4050
Jan 22, 2022
Florida
I was swapping out the glow plugs and I broke one of the glow plug cords. The cords link the glow plugs. I know that some glow plugs are linked by one piece. The
The Kubota dealer said it will be 5 business days before the new cords come in.
I broke one of them. I would really like to use the tractor to put hay out. Should i get a piece of Copper wiring and use that temporarily in place of the broken cord? Should I tape over the end of the glow plug that is missing the cord? I think if you are on the right side of the tractor looking at the engine the cord that broke is from the 2 to the third glow plug from the right....there are 4 glow plugs. Thanks for your help.
2,048
Just use a piece of copper wire. Try to use a piece of solid wire from household wiring (romex) of similar size to the existing wire. Just be sure it is floating in air and can’t touch anything else that would ground it. You can leave the insulation on most of it but make sure it doesn’t get too hot and start melting. I think the amperage will be within the wires range.
8,743
That's just a aluminum piece of wire, and yes you can use a piece of copper in its place like @Russell King said.
Dustball
2016 B2650HSDC
Sep 15, 2023
416
272
Hudson, WI
You're in Florida. You should be able to start the engine on three of the four glow plugs. Just rearrange the cords so the first three in the series are connected leaving just the one glow plug non-functional for now.
8,743
HAHAHA, It's a 6 cylinder, so try 5 of 6. 😉
8,743
The Kubota dealer said it will be 5 business days before the new cords come in. View attachment 151689
I hope there are 6 glow plugs, being that it's a 6 cylinder engine.
Airgator
Kubota M4050
Jan 22, 2022
Florida
should I skip one on the far left or the far right? Thanks.
2,048
Just put a piece of wire on it then you don't have to skip any.
I think his last question would be better asked something like this:
If I want one glow plug to not be in operation for some few days, does it help to select any particular glow plug to eliminate? If so, which glow plug would be the best one to eliminate?
(I guess he doesn’t have any solid wire? So does not want to use stranded? Stranded would work if it is large enough to carry the amperes that the glow plug consumes.)
8,743
Really non is any better than the rest to not heat up.
I worry with that big of an engine that no glow plug operation could cause a serious balance issue till it fires.
