L2850 Glow plug adapter
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
So my new to me L2850 starts easy, runs good, but it smokes some, whiteish smoke. It has 2500 hours , and the maintenance records show that valve seals and #1 injector were replaced in an attempt to address the issue. No oil loss, no milky oil, and no coolant loss or abnormal system pressurization. I want to run a compression test and I have the kit from Amazon. My question is , what adapter do I need for the V1702 DI engine? Is it 8mmx 1.0 or 10mmx1.25 “short”?
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
So what worked for me was to take the longest 10mmx1.25 adapter in the kit and chop off about 1/2” so that the reach matches the reach of the glow plugs. I then chucked it up in my drill press and finished the tip with a file and put a small taper on it. Final polish with some 400 grit sandpaper and it works great!
11,109
That engine and other in its class are the hardest to do compression tests on because of the odd Glow plugs and the Odd pencil Injectors.
You sound like you got pretty good results.
The problem with that glow plug adapter is it doesn't have a sealing surface on the top of the threads like the glow plugs, so your results can be off if the threads don't seal.
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
The glow plugs have a slight taper near the end to aid sealing. I attempted to duplicate that taper with the file and drill press ( my hillbilly lathe LoL). Really love the fact that you have to pull the lines and intake just to do a compression test. Reminds me of working on my sister’s ‘75 Honda Civic. Everything was a PITA!
11,109
They seal at the green arrow not the red arrow.
3,100
11,109
Yes but the end of the adapter does bottom in the glow plug hole. Not sure how well it seals, but the taper should help
Pipe dope on the threads would help too.
Or better yet as Russell pointed to, a nut with a taper on the face would be great.
