bx 25 4wd
Eric michaud
bx25 2011
Mar 16, 2025
15
canada
i have a bx25 2011 with 550 hrs. for 4 weeks ago i begin to have a 4wd issue. for keep in 4wd in need to keep a pressure on 4wd arm. problem with a gear??
10,246
Check the linkage thoroughly first!
10,246
parts 50 and 60 is for?
i check tomorow, just allignemnt
Detent, they give the lever that click when engaged and disengaged.
You could check that the spring is not damaged, but highly unlikely that is your issue.
10,246
You will not open the HST, you will open the Transmission, they are different!
