B6100D front crank seal replacement?
krustyman
b6100
Sep 13, 2024
9
canada
Any tips for doing this from someone who has done it already?
Mine is leaking and time for a replacement. Lools like I will need to remove rad, but am more concerned how ro physically get seal out. I see there is an o ring in there too.
11,248
Walk in the park...
Remove side panels and grill.
Remove radiator
Remove belt and crank pulley
Use hooked puller (harbor freight has them) or slide hammer with screw tip, or just a screw and a pry bar works too, pop the seal out.
Then on the crank you will see a smooth sleeve on the crank, that comes off with hook tool or pick Note the direction that it's in the now, behind it is the O-ring.
Inspect that sleeve, it will more than likely have a groove worn in it.
If the groove is off set you can flip it to get a good seal surface with a new O-ring behind it.
If the groove is in the center you will need to buy a new sleeve and O-ring.
krustyman
b6100
Sep 13, 2024
9
canada
Thanks!
Appreciate the wisdom.
Walk in the park...
Remove radiator
11,248
I am trying to get the front nut off the pulley with 1/2" impact and so far a no go. Washer tang bent back. Adding some heat and penetrating oil.
Lock the flywheel with a pry bar.
The nut is normal threads I do believe so CCW to remove.
i will confirm that in a couple minutes
krustyman
b6100
Sep 13, 2024
9
canada
Where can I access the flywheel without splitting the tractor? I do have a 1" impact that works on everything but not ready to bring that out just yet 🤣
11,248
Cover on left side (some models don't have it) or starter
krustyman
b6100
Sep 13, 2024
9
canada
Used a 5# sledge on a ratched on the nut for just enough impact to break nut free. Harmonic puller removed the pully in 15 seconds. Seal is out. Just need to get key out and spacer off. Then order parts. 🄳
krustyman
b6100
Sep 13, 2024
9
canada
It is done, not leaking and purrs again. Thanks for the tidbits. Was pretty straight forward. Will do spring tuneup next week to be ready for some gardening prep in a month.
Was dumbfounded at the $150/hr shop rate at my local Orange dealer.
11,248
Glad to hear it all went well for you!
