Irritate noice when forward/reverse H-speed B3150
K- fan since 1994
B3150 and 27-4 Exc
Feb 22, 2025
Norway
I have some irretating noice when I enganged the pedal forward and reserve on my newly bought B 3150 . Only on H speed, the other two positions quite normal.
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
337
100
Ottawa, ontario
I think what your describing is your hydraulic drive amd its normal. Called hydro whine.
2,049
You might want to replace the transmission fluid with SUDT2 (synthetic oil). It supposedly has made a difference in the whining on the tractor.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
782
679
E.
can we get a little more info? like do you know:
- does the noise change between a warmed up engine/oil and cold?
- is it worse in colder temps say at -30 versus say +15
- does it change if the operating rpm set low/med/high
- when engaging the "pedal" in high range are you feathering into it until machine is rolling or are you hitting the pedal hard and fast (like dumping a clutch on a sports car in 3rd gear at low rpm versus dumping in 1st gear at higher rpm )
- is this occurring when pointed uphill and downhill (aka worse when more load on it)
- do you have any equipment hooked to the back, are tires filled, etc...) also trying to asses a load thing in high range.
8,743
Evaluating sounds over text is like... well... Just not good.
Make a video / audio of it doing it and post it on Youtube and give us a link to see / hear it.
You could be having a normal HST whine or you could be having a host of other issues.
6,873
@K- fan since 1994 is from Norway.
Bet it's cold there.
A video/audio would help, like Wolfman said.
If it's only in H range, he may need more engine RPM, or he's trying to do things in H range he should do in L range.
Maybe a change of fluid/filters would help too, as @Russell King pointed out.
K- fan since 1994
B3150 and 27-4 Exc
Feb 22, 2025
Norway
I bought the 2020 m, 230H traktor by a JD dealer in January and proved it for only 10 min. I have been driven B2100 for almost 25 year so I noe the HST system . The noice at Hi speed was much more than I expected, but it could be lack of oilchange and or filter. The traktor is delivered with SUDT2 Oil,but change about 200 H is scheduled. When I Get it in my backyard end of March I let you noe some more .
