Winter Tilt Issues
ZD326S
125
Owensburg, Indiana
Hello, My M6800 has been having bucket tilt issues this winter, the lift is okay and three point hitch is okay! The lever seems stuck from going to either side to operate the tilt. Eventually after some time it may break free but seems difficult to operate. All other hydraulics seems to run smooth. Appreciate any help to better understand what’s going on. I use a UDT compatible fluid. It has been bitter cold during these operating times. Thanks!
9,744
You need to look at the detent section of the loader valve.
It could have frozen water in it causing the issue.
Give me the loader model number and serial number if you can, and I'll point out the part to look at.
9,744
That what I was afraid of.
My new diagnosis is you have water in the cable assembly.
You'll need to get it opened up and check the cable operation.
ZD326S
125
Owensburg, Indiana
So showing my rookie understanding of the operation, you’re saying these are cables that operate the hydraulic valves and not fluid. So removing them to inspect and remove the water will not require draining fluid but probably entail lots of tedious small hardware/mechanical features? Or is it fairly simple process? I do have the drawings for the valve but never have taken any of it apart. Thanks for your knowledgable assessment!
9,744
Yes no fluid involved:
You can do a non disassembly troubleshooting of the cables if you have a heat gun to be able to heat the cable and see if full function returns.
ZD326S
125
Owensburg, Indiana
I will sure give that a try. I really need to do a complete go over of all my hoses and hookups as you can probably tell from the pictures. With a lot to learn there are things that happen on the FEL that has me guessing. Times when under extreme pressure some of the connections leak or will stream fluid. By once the pressure subsides the leak is gone. And over the years I added to the valve system an additional system push button lever to operate my grapple. So any standard maintenance tips for the hydraulic system is appreciated. Thanks for your assistance!
2,536
For the hydraulic leak (under pressure)…
Kubota uses open center system so there is normally not much pressure in the system until you activate a valve. So that is why those leaks are only in the sometimes leaking situation. If the couplers leak under pressure then you will need to replace an oring in the female half or replace the coupler half with new.
ZD326S
125
Owensburg, Indiana
Under just normal operating pressure there are no leaks noticed. But do notice a hint of leaks around the valve area as you maybe able to tell in the pictures. Just didn’t know if there were standard maintenance to do in the valve area or to the valves? Or a standard rule for replacing hoses? Many thanks again!
