I have a friend and he tore into the fuel pump on a F2400
9,077
I specifically said the 'DIYer' WOULD have the proper tools and instructions so again what's 'magical' about them ? Gus rebuild complete engines, trannies every day... Heck I know a kid( he was 16 then ) tore his C6 out of his 69 Mach1, totally rebuilt it in a single car garage, gravel floor, used my '67 Ford WSM .
I've rebuilt HSTs for riders over the years, lots of parts in them...
I rebuilt the hydraulic pump for my CA, 3 piston, 3750 PSI. Only problem was 2 hrs looking for the check ball that went 'walkabout'., so what's the 'big deal' ?
It'd be nice to see actual diagram of 'what's inside'.
Yes, I agree that the guy shouldn't have opened it up since he didn't have proper documentation but in the end , it's just a bunch of parts,someone, somewhere assembled.
Just because you think something is so does not make it so.
The DYI'er in this post and 99.999999999% of the DYI'er's do not have the proper tools.
A DYI'er does not have a pressure bench that moves the individual pumps to do any tests.
They do not have a pressure test rig to be able to test the individual pumps, let alone know the proper shim to put in the pump to make up for the spring differences, to set the pressures.
Then without a computer controlled test rig you can't set the curve on the pump to get the timing right between the injectors.
The DYI rebuilt pump might or might not put out fuel.
The DYI rebuilt pump might or might not leak.
The DYI rebuilt might or might not supply the proper PSI to pop the injector
The DYI rebuilt might or might not pop that injector off at the right time.
The DYI rebuilt might or might not pop all three injector off at the right time.
The DYI rebuilt pump is 99.999999% junk at this point.
3,236
1,665
All do-it-yourselfers should have one of these. Without one, setting, calibrating, and testing an injection pump is nearly impossible.
Reactions: 6 users
5,762
Dang W, you into beekeeping too ??? I almost brought one home from scrapyard 2 years ago, SS, 4' round, it was sooooo pretty, make a nice 'yard art' piece ,heck never rust !!!
Considering the cost of pumps, do one a month, pays for itself in a year. That's pretty good ROI !
MOOTS
MX6000
Jun 27, 2019
2,186
2,712
Canton, Georgia
Yeah, I think I have one of those in the back of the shop. But I can't get at it because the heavy metal centrifuge is in the way.
Mine is stashed away behind my atom separator, and it’s just a bear to move.
Hugo Habicht
G1900
Jun 24, 2024
785
1,112
Ireland
Now this is some mighty statement.
Using the whole worlds population and not just the Diesel pump DIYers, this percentage leads to ZERO persons having proper tools. I know TWO people that own the proper tools and such a pump test bench. So the percentage is clearly wrong. q.e.d. :)
5,762
Kinda wonder what farmers in say India or China do when their tractors need injector pump repairs ?
I saw a TV show on Indian tractor making plant, under 'one roof' they make the steel,castings, gears,engines,assemble and at a fast pace. Truly impressive for a '3rd World country', though they do have most people in the World, surpassing China.
9,077
OK Sean, clarification needed:
So you have these tools or am I just cornfused/Alzheimer's flare up?
No I don't have that unit, would l love to, but there is way too much wood in the Shop! 😉
