Rear axle housing removal advice on L47.
Gunner
L47
Jan 12, 2025
Hey ya'll, new to Kubota and new subscriber on here. Wondering if anyone has advice on removing rear axle hubs on an L47 to replace seals. With tire, fender, hy lines, and upper support plate all removed, it appears you still don't have clearance to pull off. Thanks in advance.
8,766
You need to drop the loader frame down, It's quite the task.
8,766
Being built that way is what makes the L47 Tough!
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
366
526
SE, NM
Did this on my L45. You aint got to the fun part yet.
6869704x4
Jun 29, 2011
366
526
SE, NM
My work area looks like Joes
That's a 2 1/2" socket
Loader frame dropped, lots of stuff in the way.
Still had to rotate the housing to get it out. It's heavy.
Back together
Gunner
L47
Jan 12, 2025
Back together
So it looks like you left the full ROPS attached on the frame, did you also leave the loader arms connected and just rotate the back frame down once disconnected in the rear? And the puller/socket was used on the inside bearing? Good pics though.
6869704x4
Jun 29, 2011
366
526
SE, NM
I'll help you out as best I can. I didn't have a WSM. I do now
8,766
You do not want the loader on the tractor when you drop the frame!
