Kubota B7100 Indicators not workng
John Williamson
Kubota B7100
Jan 10, 2025
Wiltshire, UK
Hi
I have an old Kubota B7100 that I have been tarting up. I have repainted it, changed oil, oil filter, fuel filter, fuel filter and replaced air filter. Still to replace gearbox oil.
i have replaced the broken headlights and rear lights and horn. Everything works apart from the indicators, none of which work. Both front and rear indicators obviously each work in one unit with sidelights and wiring has been replaced.
I have not yet checked the connections on the main instrument cluster but as I did not do anything at the cluster for side lights, horn etc, assume that wiring should be ok.
Any advice much appreciated.
I also am having problems getting the steering wheel off, the tractor has been sat for quite a long time and it is also quite old. I have tried hub puller but find the legs of the puller just slip on the steering wheel boss. Any ideas
One other thing that I want to do is to replace the bearings, oil seal in the front axle. When I first got it going there was a grating type noise from front wheel area but for some reason after repaint etc the noise has gone!
How easy is it to replace the bearings in the wheel hub, front axle.
Thanks
John
je1279
Dec 6, 2020
828
585
Upstate NY
My guess would be it needs either a flasher or a new switch assembly.
9,279
There are glass fuses under the dash for lighting.
Yes the steering wheels are a beast to get off.
In the past I have made plates that go under the wheel hub to get a better bite, then another trick is to get tension on the puller the a smack on puller bolt will help break it loose.
Soaking it in penetrating lube helps too.
3,185
I had to do all three (plus heat/cold) to get mine off intact.
John Williamson
Kubota B7100
Jan 10, 2025
Wiltshire, UK
Thank you for your reply. I have tried freeze spray and now have been soaking it in penetrating oil for a week. I will be making up my own puller as well
John Williamson
Kubota B7100
Jan 10, 2025
Wiltshire, UK
Thank you for all your responses, much appreciated. Any one renewed the bearings on the front axle, is it a bugger or fairly simple
9,279
If your mechanically inclined it's an easy job.
There are 2 different axles depending on which model you have.
3,185
Thank you for your reply, I am trying freeze spray, soaking in penetrating oil for a week and will make up my own puller, shop bought hub pullers just slip on the steering boss
I made a plate a little bigger around than the hub, with a slot for the shaft cut to the center, 3/8" plate if I remember.
Then the puller had something solid to grab.
3,185
tsp159
B7100D
Feb 8, 2023
103
58
Fort Bend Texas
I used a large bearing puller to pull my steering wheel. It did not respond to heat (melty) or penetrant. Even tried tapping holes into the steel and that did not work.
Something like this worked. It fit in the gap between the steering column and the back of the wheel. Took an unnecessary amount of tension to release it.
The flasher relay is accessible with the dash on, it should be held in a rubber grommet/boot that bolts onto the backside of the dash. The switch could be corroded internally if the tractor spends all its days in the weather. Also, if you have LED bulbs in the flasher circuit, the self-driven two post flashers that come stock will not work. You'll need an electronic flasher with a ground - the dash grounds through the steering column so make sure the column and backside of the dash are clean of corrosion when you reinstall.
