Pinout Hyundai excavator pressure sensor wanted
Hugo Habicht
G1900
Jun 24, 2024
593
792
Ireland
Hello,
I am looking for the pinout of those pressure sensors used in Hyundai excavators like the R140 or R210 and others.
Kind regards,
Hugo
Hugo Habicht
G1900
Jun 24, 2024
593
792
Ireland
Well, If I would own one of those excavators it would not be a problem. But I want to buy one of those sensors and use it in my Kubota. It may be protected electronically but I would like to avoid frying the sensor. Hence my question.
And I do not have a wiring diagram. I could not find any freely available service manual on the internet.
5,684
OK, just HOW are you going to use the sensor ? How was it calibrated? does it output a voltage or current when pressure is applied. Is it linear, semilog or log calibrated ? Hmm, is it peizoresistive ???
Without seeing the actual datasheet for that sensor, it may not be 'compatible' with your Kubota.
From the picture it's '50 Bar' so about 725 PSI, so not a primary hydraulic sensor....
The actual easy part is buying the mating connector !
Dustball
2016 B2650HSDC
Sep 15, 2023
416
272
Hudson, WI
You'd need to find the excavator model that those were used on, then find the wiring diagrams for the excavator, then find the sensor on the diagram.
Never mind, I went and did the work for you.
CD-42/43/44 is a Deutsch DT06-3S-EP06 connector.
Hugo Habicht
G1900
Jun 24, 2024
593
792
Ireland
Hello Dustball,
You'd need to find the excavator model that those were used on, then find the wiring diagrams for the excavator, then find the sensor on the diagram. Never mind, I went and did the work for you.
that is great, that's what I was looking for, thank you very much !
Where did you find that or which keywords did you use? I did not find anything, only websites asking for a lot of money.
@GreensvilleJay: yes, it is compatible with my Kubota. I built the electronics for the sensor myself and I will calibrate it in software too. I also believe the pressure range is suitable.
Kind regards,
Hugo
5,684
nice when a plan comes together !
never thought about the 24 volt battery....
the 1 volt for 0 bar makes sense, as does 5v for 50 bar (full scale)
if you use Olympic averaging of the raw signal, you'll get nice steady numbers.
Hugo Habicht
G1900
Jun 24, 2024
593
792
Ireland
Hello,
just some feedback: I ordered a sensor 31Q4-40830 which has a 50bar range. The pinout is: A-Supply Voltage B-Output C-Supply Ground, the letters are on the sensor connector.
The sensor is specified to work from 8 to 30V, so although used in a 24V supply excavator it will work fine in my Kubota with 12V supply.
Many thanks to Dustball again for pointing me in the right direction and also for providing the mating connector number which was most helpful. (y)
Kind regards,
Hugo
