2012 Kubota RTV 400CI
Faith
2012 Kabota RTV 400
Dec 26, 2024
Gilmer Texas
Serial # 10282
Kubota GH 400 ES 06OHV gas engine
Engine turns but no compression. Can this engine be saved? Is there anything I can check to find the problem? They no longer make this engine.
3,299
1,714
Serial # 10282
What is the compression on each cylinder?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
These engines had a problem with getting gasoline in the oil when operated in colder climates. Have you checked that and changed the oil? These were built by Subaru,
3,299
1,714
Only one cylinder and no air coming out.
Duhhhhhhh, you have an RTV400, but I was thinking of an RTV500 which has a 2-cylinder engine.
Have you removed the rocker cover and checked that the valves are opening and closing?
You can also remove the sparkplug, insert a stick of bronze rod through the hole resting it on the top of the piston, and turn the engine over by hand. If the piston does not move you have a broken connecting rod.
Faith
2012 Kabota RTV 400
Dec 26, 2024
Gilmer Texas
I will tes
I will test that thanks
