ZD326 shutting off
Chascoll50
MX5100
May 15, 2021
15
Georgia
I have a used zd326 I recently picked up at auction. It does have issues starting, and I read a related post in the forum, and I will try those suggestions. After I do get it started, the machine runs fine, and cuts fine. I was cutting for about 2 hours and wanted to take a break. I disengaged the pto, and reduced throttle. After the throttle was just above idle, the machine shut off, and would not start back up. This has happened twice so far. As long as its 50-100% throttle, its fine. Any suggestions?
Digger Dager
M59 TLB, B3200 w/front snow blower, 3 @ ZD326 62" rear discharge mowers
Welcome to the forum. First thing I would check is the fuel filters, fuel lines and tanks for debris. Next would be the electric fuel pump itself. Also check the air cleaners. If they are too clogged, the engine will be starving for air.
We have 3 of these things, and they are excellent. Our oldest just turned over 2,500 hours.
Digger
5,515
2,229
Going out on a limb, since I'm not there in person to see/hear it, but it almost sounds like it's a wiring issue of some sort. Vibration from the 3 cylinder engine is most pronounced at just above idle. I am thinking the vibration is causing wire(s) to either lose contact, or perhaps make contact where they shouldn't be, at that point. I may be wrong.
Chascoll50
MX5100
May 15, 2021
15
Georgia
Digger
Yes, I had changed the fuel filters, but it wouldn't hurt to do it again, especially if there's a good bit of trash in there. I will definitely go through all the wiring, given the starter and also a non functioning fuel gauge on the left tank I hadn't mentioned.
5,515
2,229
the control arm switches, if open (arms in), will prevent the engine from cranking over. So will the PTO switch if the controller thinks the pto is "on". Similarly, the OPC switch (seat switch). Thus if it cranks over fine, those switches are probably working.
Chascoll50
MX5100
May 15, 2021
15
Georgia
I agree, and I’ve had other machines where those switches have caused problems. Haven’t solved the issue yet, but will keep digging. Thanks
