Creep / Leak? down. B1630 loader on B7100HST-B
5,609
OK, I'm understanding more. SS shipped me plugs and I will test to confirm the (Very Likely) problem is the control valve leaking.
Today I moved 6 logs from a big maple that came down: about 24" by 48" pieces moved to buck up and split. I used a chain on the hook on top of the bucket and then picked them up into the bucket, one by one. Put 3 on a trailer and ferried 3 down the road to the yard and woodsplitter near the woodpile. The creep down was much more pronounced with the load. Had to keep blipping it back up.
So I'm looking at valves. The Summit valve looks good. HERE . My valve has two pressure hoses from the tractor side block, and one return line. Looks like:
View attachment 136714 View attachment 136715
Might I reuse fittings from the OLD valve on the new one?? Hmmmm..
Thanks for all the help!!
I am pretty dure the ports on the Summit valve are all a different size than the OEM valve:
Summit Valve:
P, T, and N are SAE-10.
Work ports are SAE-08
IIRC the ports on the OEM valve are one size smaller
My bet is bucket droop is a bad cylinder not the valve
If you are getting boom leakdown it is probably the valve.
Test and verify before replacing anything.
TerryKing
B7100HST-D
Aug 18, 2024
178
117
Topsham, Vermont USA
arduinoinfo.mywikis.net
Hi Dan and the group,
Received the plugs from SS and I will do that test today...
ASSuming the valve is the likely culprit, I need to better understand connections.
I understand the 2 work connections for cylinder groups. But there are 3 more...
One is return to main fluid reservoir/transmission etc.
TWO come from the block on side of engine.. ?Are those both pressure? Basically the same?
If I were to get a valve like this (PS: Anything bad about this one??)
https://www.amazon.com/marddpair-Hydraulic-Directional-Control-Tractors/dp/B098JXNLCP/ref=sr_1_4
? Where would the return come from??
And Acronym Challenge: "BSPP Double Acting?? and from previous post: " P, T, and N are SAE-10. "
Thanks! Terry
5,609
Thanks! Terry
BSPP = British Standard Pipe Parallel
This is the thread type used for the ports. BSPP is the world's most common standard except in the US where we have our own national standard. You can purchase BSPP port adapters so it's not a problem but they cost considerably more than the corresponding SAE port adapters so it adds considerably to that low price. Its also confusing to anyone working on the machine. It's actually cheaper and less confusing to buy that same valve with SAE ports.
DOUBLE ACTING = controls two way cylinders
That is what you have and need.
The three connections to the tractor are:
PUMP
That is the rightmost hose on the outlet block and it delivers pressure out to the P port on the valve
POWER BEYOND (PB)
Also known as High Pressure Carry Over (HPCO) this is the leftmost hose on the outlet block. It carries return pressure from the N port on the valve back to the tractor to power the three point. You must install a power beyond conversion sleecve in the N port to use this function.
TANK
This is the hose going to the top of the transmission. It carries low pressure return oil from the cylinders back to the reservoir. It connects to the T port on the valve.
5,609
Thanks! Terry
Here is a European made version of your Chinese made valve. It has North American (SAE) ports.
Your OEM loader valve has a fourth float position on the boom spool and the Chinese valve does not. Here is the European valve with float
The OEM valve has a joystick handle.that is not going to work with any of those valves. Here is the European valve with integral joystick and a fourth float position - $249.
Finally, all of those valves require a power beyond sleeve that goes in the N port
Thats about as cheap as you are going to find .
TerryKing
B7100HST-D
Aug 18, 2024
178
117
Thanks, Dan! I did the test: Results here.. I'll be back about valves next...
Blocked up before plugs
Port to lift extend
(Trying to be sure I did this right!! Heres line to the lift cylinders "Extend")
valve port to Bucket "Retract"
Line on bucket cylinder "Retract"
Lines Plugged
OK, removed the support. Results:
LIFT cyclinders leaked down 1 inch of cylinder rod travel in 30 minutes !
BUCKET cylinders didn't move much initially, until I put my 170 pounds on the blade. After pulling bucket down to center of travel they leaked down 1 inch in 60 seconds.
* Don't ever bet on Dan being wrong, at least with Hydraulics.
SO I'm in the market for a valve, and Sometime 2 bucket cylinders. I'll be back next, when I look at all the lines again. Re: "Market" - Not absolute, but I'd prefer some Amazon valve because I have some credit there and not a lot of floating cash... SS does have adapters.
Thanks!
zz
5,609
Port to lift extend
Lines Plugged
Thanks!
A new valve is not going to do much for the boom leak down but:
Summit does Amazon
Dan has all the adapters you will need and shipping is a lot lower than SC. Also makes custom hoses.....
TerryKing
B7100HST-D
Aug 18, 2024
178
117
Summit does Amazon
Dan, Thanks for your patience with all this..
Looking at that Summit valve.. connections:
No code has to be inserted here.
What is the G connector?
Would I need a power-beyond valve?
BTW, what connectors would my OEM casting have used ?
This is like explaining ENUM to a newbie :) :mad:
Regards, Terry
5,609
Regards, Terry
G is just the current ISO designation for BSPP. G1/2 and 1/2 BSPP mean the same thing.
Your OEM loader valve has a power beyond outlet port and the replacement must have we one as well. Thats the N port on the valves we have we discussed. For the N port to function as power beyond you need the power beyond conversion sleeve.
The OEM valve has SAE ports. Pretty sure the work ports are -6 size. Not sure about P, T, and PB (N) but my guess is -8.
5,609
Hmmm. My OEM valve does not have a FLOAT position for the lift.
Is it possible to connect a cross valve between the two connections to the lift cylinders to optionally Float those cylinders? Is this ever done?? Might be good for snow plowing? Hmmm...
If the valve is OEM it should have float. Post a picture of your valve.
Edit - pictures earlier in the thread. That valve looks like OEM and should have float. Move joystick to lower position and then push hard.
5,609
Hi Dan, pushed real hard and didnt travel differently... (Photo)
BUT: The joystick is worn. I'll ty to move the spool manually...
I DID find some interesting stuff. Seems it IS OEM,, HERE
Post a picture of the other end of the spool. Here is mine. Last two pictures show position of spool in pressure down and float.
TerryKing
B7100HST-D
Aug 18, 2024
178
117
... position of spool in pressure down and float.
THANKS for taking photos and taking the time to discuss this.
I will take photos but I think my valve looks just like yours. I will test the possible positions but it looks like my total spool travel is same as yours. Does yours FEEL different in those two active positions? IS there some kind of detent?
Regards, Terry
5,609
Regards, Terry
The spool in mine is clearly further in.
There is a detent between pressure down and float.
Post a picture showing the backside like I did and we will know for sure.
TerryKing
B7100HST-D
Aug 18, 2024
178
117
your valve has a fourth position (float detent) end cap.
Sure does... Have a good photo from morning light that shows it..
AND testing in the driveway, there IS a difference between holding a smaller-movement down and an all-the-way ' FLOAT.. NO Detent though..
Saw some post about detent stuff that included small ball bearings escaping in the dirt :-( Have you had those things apart (taking bets)..??
And to try to never post without a photo, here's todays Logging work. I could barely lift/move one end of those maple logs myself. Trailer is back up to the house and log splitter. Just want to sharpen the saw first..
Thanks!
5,609
Thanks!
My valve has a noticeable "detent" but it no longer holds on its own. In fact in the 30 years I have owned it it has never held and I figured that was the way it was supposed to wotk.
5,609
Hmm... I really would like to be able to hold Float for snowplowing. Guess there's always Bungees, able to override manually.
I plowed snow using the bucket for three decades holding it in float with one hand and steering with the other. It became second nature.
If you are feeling ambitious you could take the detent mechanism apart and "fix" it.
TerryKing
B7100HST-D
Aug 18, 2024
178
117
Oh good, now I can ask an expert about snowplowing with the bucket!
Can you quickly talk about how you managed the bucket, what problems you saw etc,?? How about long passes vs shorter passes?
Most typical snow plows have some mechanism to keep from hitting the actual ground / gravel / concrete etc. Some are skid-like, some are round mushroom shape. I'm thinking of adding 1.5" thick (2x4 pressure treated) skids in the bucket holes after the snow flies. What surface were you on? I'm on gravel/dirt.
Thanks Again..
