3301 TnT kit parts list drawings
animals45
L3301l
Apr 22, 2021
282
Mabie CA
hey folks , I bought a used TnT kit last spring & there is a leak in the control assy . I have been unable to find the parts list drawing for this setup . In the attached pic to the right of the right control valve there is what looks like some kind on adjustable valve ? It's leaking from this part & I would like to see the parts list so I know what's gonna shoot out & get lost when I remove it to replace a banjo washer . Also what does this part do .
thanks
animals45
8,713
Really need the Valve model name and number to give you exact details.
5,214
thanks
animals45
Looks like you circled the pressure relief valve. It limits the maximum pressure the valve will send to a cylinder. Usually pretty simple devices with a poppet, spring, and some washers inside. Nothing should fly out but make sure you don't drop any of the pieces. That's not a banjo and probably seals with a plain copper crush washer. I assume you have already tried tightening it?
animals45
L3301l
Apr 22, 2021
282
Mabie CA
Thanks , yea I already checked & its tight . I was meaning a crush washer like with a banjo fitting , I just couldn't think of the name . I have a assortment of those here , so my plan is to clean everything up at the control valves & then run it for a bit to confirm just where the leaks is . I know its coming from the pressure relief valve just not sure if its coming from the base of the PRV or furthur up on it .
thanks
animals45
