Used b2410 turf rims with incorrect tire sizes
Jgolds
B2410
Aug 29, 2024
Sacramento
Hello. Just picked up a b2410 and saw it does have incorrect tire sizes. Now I don’t really like the tires as they are older so I’m planning to replace them but for the time being want to see if someone is able to run the conversion on the sizes and even see if they will work with 4x4
Here’s what’s on it
24x9.50 r12
35x12.50 r15
Thank you
2,858
What I have gathered is this: ( not 100% sure it is accurate)
Fronts 21x8 x10
Rear 31x15.50 x15
Doing some verrrry simple math - your tires ( assuming that a 24" tire is 24" in diameter and so on)
24/35 gives you a ratio of .6857
where as the factory specs would 21/31 and that gives you a ratio of .6774
which IF WE continue the math gives those two at 98.8% of one another.
Jgolds
B2410
Aug 29, 2024
Sacramento
Hey thank you.
looks like B2410 has two turf option sizes. What I gathered is this had factory
23x8.5 r12
33x12.50 r15
N3BP
Sep 20, 2016
499
227
Lebanon, PA
The B2410 WSM sates it could be option with the following:
Front: 21x8.00-10 or 23x8.5-12
Rear: 33x12.5-15 or 31x15.5-15 (Bar)
There are also AG and industrial combinations it lists, but assume you're after a turf or turf/bar combination for mowing.....
Jgolds
B2410
Aug 29, 2024
Sacramento
Yes. Looking for AG Bar style. My tractor has incorrect sizes on it and would prefer the factory size. I did get a spare with original tire and that was a 33x12.50r15 Goodyear turf. I believe the front match to that is 23x8.50r12.
Online found a decent front Ag bar style but having troubling finding a rear to semi match. So many truck tires come up for the rear size. No really At style other then the Goodyear turfs. I hear people just run a mud terrain truck tire in rear. Leaning that way I guess. I just prefer a closer matching set.
