Lifting zero turn mower to remove blades?
jyoutz
Jan 14, 2019
3,628
2,728
Edgewood, New Mexico
How do you all do this? I’m not planning to buy a mower lift for a couple hundred dollars. Chain trolley from barn rafter? Tractor loader bucket? I’m looking for ideas instead of dropping the deck.
6,881
I set the mower deck to max height. Put a 2.25 ton floor jack under the front axle and raise it to full height. That gives me enough room to get a Milwaukee M18 high torque impact under it to pop the blades off. Used an air impact before the Milwaukee. I put one arm under the deck; no other body parts. Worst case, if the jack fails and it falls, with the deck all the way up it still clears my arm.
That jack has yet to fail, but I’ve had a hydraulic jack catastrophically fail while I was under a truck (appropriate blocking saved me from being crushed), so I’m not getting any body parts in a crush/pinch area, and have no reason to for that operation.
jyoutz
Jan 14, 2019
3,628
2,728
Thanks. I’ll give that a try. I assume that you also block the rear wheels?
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
That is exactly what I do. Right down to the tools used!
9,118
Seriously though. Lots of folks showing off. 😂🤣😂🤣
This is what I purchased from Harbour Freight for my zero turn. I strap the carriage to prevent it from rolling off.
You drive the front tires onto the ramp. I strap with a ratchet strap for extra safety.
5,188
I put a web tie down strap around the front of the ZT mower, and lift with my loader bucket hook, until the tail end of the machine touches the ground.
I then put a jack stand under the front edge of the mower, and lower the mower until it rests on a jack stand.
Easy to then reach under to scrape the mower housing clean, and/or replace the blades.
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
275
510
Moseley, VA
Add jack stands before crawling underneath and its a breeze!
jyoutz
Jan 14, 2019
3,628
2,728
I was looking at those and they are probably the best solution, but I was trying to avoid adding more junk to store in my shop.
9,118
I got it shortly after getting the zero turn and before I owned a tractor with a loader.
My son has been using my zero turn for the past few years. When I dropped it off at his house, I dropped the lift off with it.
Of course when I repo my zero turn, I'll be repoing the lift as well 😂🤣😂🤣🤣
