M6040 3 Point "Hemorrhaging"
SoutheasternSon
M6040
Sep 7, 2015
21
AL, USA
Or so that's what I've been told it called. It's pretty obvious in the video what I mean. I don't have a clue what happened to the audio.
View My Video
Hey y'all, the Kubota has recently started doing this. I don't guess it really hurts anything, but it does bother me, even though I don't really notice it while running the BH. I've had basically no issues with the tractor since I bought it, which is great, but I have no tractor troubleshooting skills either, especially the hydraulics. Friends and internet searches haven't helped either.
So just a run down, it didn't do it when I bought it. When I shut it off it would hold and implement indefinitely. Now it won't stay up even with the engine running. I did read that if a lift cylinder seal was leaking, you could close the lowering speed adjustment, and it would leak down. If it didn't leak down, the lift cylinder wasn't leaking. Well mine didn't leak down
It does it with the FEL on as well as off. No issues with the FEL holding up the tractor overnight. Hydraulic fluid isn't low, and doesn't look to be in bad shape. Hydraulic filters are new. FEL has come down jerky with the weight of the BH on the back, but only twice.
I haven't been able to find anything Kubota specific, and didn't find any solid answers on any other tractors either, cause I figure the principles would be the same. I don't really have any idea where to start, so any help would be greatly appreciated.
Thanks y'all
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
I think there is a linkage, on the TPH, that needs to be adjusted. NIW, or one of those who have more experience with this model, can tell you more...:D:D
11,141
It's call surging, ;)
It's because the feed back linkage is out of adjustment.
I emailed you a link to download the WSM for more info.
Basically the system is telling it, it's either too high or too low and engages the valve to make up for it.
If you adjust the linkage and you can't get it to quit surging, you very possibly have a bad seal on the hydraulic cylinders or the valving and will need to rebuild.
SoutheasternSon
M6040
Sep 7, 2015
21
AL, USA
Dude. Wolfman. That will be a HUGE help to me. Thank you so much. I found the feedback lever. If it had any type of cotter key or pin holding it in, its gone so the lever was pretty loose. I have to work this weekend so I won't have time to try to get it straightened out this weekend. I'll let y'all know what I can get done on it Monday. Thanks y'all.
SoutheasternSon
M6040
Sep 7, 2015
21
AL, USA
So I took the shop manual and get the feedback lever hooked back up and set to the factory length. It's still surging.
Also, it used to hold up for a days at a time, with a 6 foot tiller anyway. Now it leaks down overnight with nothing on it at all. Where do I start to find what's wrong?
1970cs
1,124
Grand Ledge
Wolfmans last sentence, "cylinder/piston seal bad or control valve issues" Either way, the lift cover has to come off.
Pat
Tooljunkie
May 13, 2014
4,150
35
I make it a habit to lower any implement or load on my hydraulic systems. Leaving something in the air unnecessarily is hard on seals and potentially dangerous.
So with the three point up and valve closed while machine off the three point stays up? Then control valve needs service. If its dropping then cylinder needs service.
I cant imagine the parts are all that expensive. Clean before you go in and keep it clean. This way you minimize risk of getting dirt inside and damaging something.
SoutheasternSon
M6040
Sep 7, 2015
21
AL, USA
I agree. I try not to let things stay up. Not that it matters now. But I guess that's why the tiller stands out to me. I don't usually leave things up. Seeing that tiller up for a few days was out of the norm.
I tried the lowering speed knob off and it doesn't fall. So it seems like it will be the control valve. I'm not sure if I'll do it myself or take it to a shop. I read the WSM about the removal of the cover. It doesn't look to bad, but I'm leery of it because I've never messed with hydraulics.
11,141
EDIT: Misleading info was given.
On your model you have 2 remote cylinders that lift the three point.
It's real easy on the model to find out if you have a bad lift cylinder.
Remove the small clamped hose (#150) on the top of each lift cylinder lift the three point and if fluid comes out either top port and the lift falls then it's got a bad cylinder.
If they fall but no fluid comes out, you have a valve issue.
SoutheasternSon
M6040
Sep 7, 2015
21
AL, USA
This is frustrating. I was moving some hay yesterday. Put a spear on the back. Went to pick up a roll and I couldn't set it down. 3pt wouldn't do anything. Not up or down. Had to wrap a chain around the roll a drag it off the spear. 3 pt started working fine.
I tried it again on another roll just to make sure. Wouldn't do anything with weight on it. I cut the tractor off. And after a few minutes it just seemed to release and the 3pt fell, because I had it on the lowest setting. WSM says this is the control valve.
Ill check the lift cylinders like Wolfman said here in a little while.
ETA: Pulled off the clamped hoses. No fluid. Definitely is the control valve. Thanks for all the help and input. I'm probably gonna carry it to the Kubota place. I see this as something i could make worse by opening it up and messing with it.
billy18c
Kubota M6040-DT
May 15, 2024
South Carolina
Hi everyone, I have a Kubota M6040 DT that is doing something similar to what SoutheasternSon's original post. I've completed some trouble shooting and can't seem to figure out the issue. The 3pt lift only pulses with a load and doesn't do it with nothing connected. 3pt lift is also operating very slow even with running higher RPMs. Front end loader and other hydraulic components appear to be working fine. Hydraulic fluid level is within the marks on the dipstick.
First, I went through the steps to check the position control lever was set to factory guidelines per the attachment. I also saw where someone posted about a similar issue with cams sticking (https://www.orangetractortalks.com/forums/threads/m7040-lift-problems.24062/), but I haven't looked into that yet. Lastly, I disconnected the hose from the top of my cylinders like North Idaho Wolfman instructed in post #10. After disconnecting the lines, I lifted the 3pt hitch and fluid didn't come out until the lift was about halfway up. Once the lift was as high as it could go, the fluid stopped, but the lift didn't leak down, it stayed up. Full disclaimer: the hydraulic fluid/filters are due to be changed so I have the filters and fluid, but I didn't want to put brand new fluid and potentially have to drain it all back out to fix this issue. Thoughts?
11,141
If you disconnected the hose off the top of the cylinder and you have fluid coming out, you have a bad cylinder.
If you want to verify it further, you can put individual hoses off each cylinder into bottles, if the bottles fill with any fluid after a few uses then their is your issue.
billy18c
Kubota M6040-DT
May 15, 2024
South Carolina
So I need to remove the cylinder and find a repair shop to rebuild it? I’m just curious, but what is the purpose of the line at the top of the cylinder that I disconnected? Is it a return or something? If everything is operating correctly, it should always be dry, correct?
11,141
I don't think those cylinders are rebuildable, but I could be wrong.
The line out the top is a vent (air) line, and not a fluid line.
It's a single action cylinder, hence the reason there is only one pressure line.
