N NAPAparts New member Equipment FZ2400 Jan 14, 2024 2 0 1 North Dakota Jan 14, 2024 #1 Wondering if anyone has replaced a clutch on a FZ2400 and if so how hard it is? Thanks, Jason
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 36,511 11,278 113 Sandpoint, ID Jan 14, 2024 #2 There are 2 clutch pack which one are you talking about?
N NAPAparts New member Equipment FZ2400 Jan 14, 2024 2 0 1 North Dakota Jan 20, 2024 #3 I believe it is the larger one, the machine will start and run but will not move.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 36,511 11,278 113 Sandpoint, ID Jan 20, 2024 #4 That's a fairly easy repair. you just need to pull the left NAPAparts said: I believe it is the larger one, the machine will start and run but will not move. Click to expand... I would suggest getting the WSM and following it to troubleshot. There are too many other possibilities for it to just be that, for the reason for it to not move. Work Shop Manual for Kubota Front Mower Models FZ2100 and FZ2400 | eBay Part listed replaces part numbers and fits machines listed, however there can be other part numbers depending on when the machine was built. www.ebay.com
