Kubota D1803-T oil pressure switch
Austin3798
D-1803-T
Dec 5, 2023
Idaho
I have a Kubota serial number: 7MD6420 code number: 1J497-20000 and when it’s in park I can start it and increase/decrease RPM no problem oil pressure is fine but when I try to drive it in any RPM after a bit the oils pressure sensor will shut off the engine. I believe I am getting above 30 PSI in operation and I cleaned/checked the connection on the sensor every looks good. Is there any way to troubleshoot the oil pressure sensor measuring ohms are resistance?
5,779
IF this is a switch ( go -nogo ) oil pressure sensor
remove from engine, use air pressure to test.
Zero air pressure should give 'open' or infinite resistance or no beep
25-30 PSI 'closed', zero ohms, beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeps
depending on age, sensor could have a ruptured diaphragm( rubber that keeps oil off switch contacts ). if that's the case,you can get random,weird, operations like shutdown.
curious , how do you KNOW it's the oil sensor causing the shut down ?
9,196
What is the engine powering?
Kubota normally never put a low pressure cut off on their engines, so I'm wondering if it's an option to the equipment it's running.
3,638
I have a Coleman PowerMate generator I use with the Airstream trailer when boondocking and it would randomly shut down. I got tired of troubleshooting it when it dawned on me it’s equipped with a low-oil-level shut-off system. I cut that wire and it’s been running reliably now for the last 4 years just fine.
