[MOD] Exhaust Re-Direct
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
Exhaust Re-Route
Another Mod.
Keep scrolling for the final application.
I dug through my goodies and found some Stainless, to route the soot away from painted surfaces. 1000015688.jpg
Reactions: 7 users
GrizBota
L3830HST/LA724, B2601/LA435/RCK54-32, RCR1872, CDI 66ā€grapple, pallet forks
Apr 26, 2023
1,147
733
Oregon
Nice job.
Hey, I need one too for my B. The new JU Fab tiedown bracket is right at the exhaust tip. The power coat is baked brown now after about 3 hours of use.
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Nice job.
Would you believe if I said, I've searched and searched (online, muffler shops, scrapyards) for about 15 years. Thinwall pipe is not found much outside the industry who consume it. It's almost unobtanium, so when I do find something that works without jerry-rigging, I try to get a few feet. Aside from my days of making wind chimes that are hanging on my home, my stash is gone.
3,570
My muffler/exhaust pipe was horizontal when I bought the tractor, where it deposited soot & burned FEL hoses.
But it was easy to flip vertical & add an extension. :)
Trimley
Jul 25, 2023
1,181
872
PNW-WA
I found a better solution. I had an FMF Tuned Pipe and Header (4-stroke) left from my racing days. Stainless, and it slips snugly over the stock exhaust pipe. Final rendition is one piece.
Those wanting to redirect the exhaust, you might goto a motorcycle repair shop or motorcycle salvage yard to get a header pipe. Stock exhaust pipe (O.D.) size is 1-1/4" on my BX23S. You need a thinwall tube (1-3/8" I.D.) to slip over snugly for best results. Don't forget to get a clamp while there. 1000015727.jpg 1000015779.jpg
5,515
2,226
This post reminds me....
few years back i had a a good customer of the kubota dealer contact me ( a few days after I quit that dealer) looking for someone to fab a tailpipe turnout on his ZD mower. I said "I bet I can do it". He brought it over, bagger and all. That's why he wanted a turnout. The original tail pipe points directly at the bagger. Being a diesel, it needed little to no restriction. The way the "hood" (aka bonnet) is shaped, the tailpipe also could not be clamped to the original, so that the hood could be raised without him having to remove it every time. Important when you're dealing with older folks, the less work the better. A turned-out/down extension would also need to run somewhat cool, as not to hurt the bag, since it was in close proximity.
On the way home from the new job (first day too) I got behind a Ford diesel pickup. I just happened to notice the tailpipes and how they are "intercooled". I remembered that the new boss actually had one of those trucks so the next day I went to his truck in the parking lot and looked at the tailpipe trying to figure it out. All it really does is speed up the air flowing through it, and draws in cooler air due to the pressure drop (as velocity increases pressure decreases). Ah-hah! Went home, made about a 110 degree turnout for the mower that bolted to the back of the hood. Then I drilled 4 holes in the extension and dinged the holes such that they actually reduced the diameter slightly while allowing air to be drawn in from outside. Drove the mower around a few minutes while the deck was on, full throttle and measured the outlet temp of the original exhaust pipe (under the hood), which was about 550 degrees F at the tip. My intercooled exhaust extension? 145 deg F. Success! Painted it up with some John Deere Muffler Black paint (the best high temp paint i've ever used) and delivered it back to the guy. He was VERY happy about it, especially the fact that he can raise the hood without having to remove the extension. Work from home again was the plan until "they" (new boss) contacted me.
The best part? The guy I work for, it's his dad. I didn't know I was gonna work for him when I started the project, I actually just quit the kubota dealer and hadn't decided what I was gonna do yet. Worked out well. Mr Charlie still to this day raves about how well that tip works.
Scrap yard. Someone mentioned that. I used to frequent the local one before they cut off all customers from being able to walk around in the yard. At the time I was building a turbocharged Ford Maverick (that nobody at the time had done) and needed some intercooler tubing. I was looking for 2 1/4" steel tubing. I wanted steel because it's cheap. What I found at the scrap yard was about 100 total feet of various straight and bent 2 1/2" aluminum thin wall tubing. PERFECT for intercooler fab. I bought all I could get, used about 6 feet of it and sold the rest on the markets. Great buy, for $6.
leveraddict
Apr 1, 2019
905
594
NEPA
Just put a stack on mine! LOL!
leveraddict
Apr 1, 2019
905
594
NEPA
Whhaaatcha ya got going on there? LOL
It was just a joke I played on old sidecarflip a while back! He's no longer with us!
leveraddict
Apr 1, 2019
905
594
NEPA
I think it looks a little shnazzy! Its a Yamaha exhaust and air cleaner I took off my old bike! LOL! IMG00011-1.jpg
bbxlr8
Mar 29, 2021
455
314
Eastern PA
Those look great - a ways back some people posted about using RV generator exhaust extensions off Amazon. Haven't done it yet myself but would be a great idea
5,600
I did the same thing with a piece of chrome P trap,, hey it works
