Hello, hoping you can help with the below issue on my L4701. When putting away hay for the year, we noticed a lot of fluid leaking from below the seat. It is steadily oozing from the dipstick, that's on the left side of the driver's seat. This is after running at high RPM's for a while, and using the hydraulics a lot of lift round bales
It looks to me like this is the hydraulic fluid dipstick. Online I read that it will leak from here if the fluid is too full. I've had the tractor for about 100 hours, and have never added fluid, so I'm not sure it would be overfilled at this point
I spoke to the Kubota dealer here, and they told me the rubber tube next to the dipstick is a vent tube, and is probably clogged, which is making the pressure too high, and therefore the leak. Looking at the tube though, which is question mark shaped, it looks like there is no hole on the end, so I am not sure how it would have vented in the first place
Any suggestions for repair, or any ideas for what to check next would be greatly appreciated
