Speedometer stopped working
cthomas
LX2610 HSDC
Jan 1, 2017
846
561
La Farge Wi
Which tractor? Remove cluster and operate tractor does cable spin? Or using square bit carefully power the speedometer with drill, does speedo work/move?
8,744
Come on don't hold back!
Now Which M7040
5,684
Gee 2011, I'd think it wasn't a cable driven tach..maybe a signal off the alternator going to the dash( computer ) ??
If everything else on the 'dash' functions fine, check alternator wiring, locate the signal wire, check for pulses.
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
3,245
1,860
Where do I look for the sensor/cable or is that the likely problem. Display shows 0
If it's any help, here's the schematic. 23 is the traveling speed sensor, 24 is the engine speed sensor. I'll do some more looking.
8,744
The WSM has all the testing and location information.
It's not a simple system.
Look at the envelope top right of the screen
