Redoing the driveway
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
320
215
ottawa
New project starting today
I was tired of blowing gravel all over the place in winter so i'm going with recycled asphalt.
I borrowed a box scraper from a guy nearby. It's my first time using one of those.
The plan is to scrape it all, move it in a pile in the backyard. Then I'll get about 36tons (2 x 12 wheelers) of recycled asphalt.
The gravel looks way nicer and is very effective at draining water so I'm kinda bumed out that it's just not workable in the winter.
I'll have to grade everything perfectly so water doesn't pool (non issue with gravel) and I hope it's not gonna be as messy as stone dust on the front door inside carpet.
5,188
After the Summer sun bakes on your recycled asphalt for some months, you will have what will look like an actual asphalt driveway.
I think you will be very happy.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
Perfect time of year to do it! I'm actually getting close to performing this same project myself. Just trying to plan timing with all the other stuff going on this summer.
3,156
Can you put a layer of stone on top and roll it down into the asphalt?
Could you just compact the gravel with a roller compactor or would the freeze thaw cycles break it up? Being from Texas we don’t really deal with that problem here.
6,328
stuff I know....as I put 4K$ worth of it down 8 year ago...
RAP MUST be driven on it or it'll 'crumble' and get loose as there is NO 'binder'.
You can fling it pretty good with a snowblower until it freezes solid.....
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
do you mean continually driven over, or that it needs to be compacted initially?
Seeing as I am planning on doing our RV loop, it will go long periods of time without getting driven on.
7,356
Doesn’t look like you have a surplus/thick layer of stone.
I’d be apt to put scarifiers down on the borrowed box blade and churn/blend your existing stone a little. I wouldn’t peel it off.
Then regrade everything with box blade with scarifiers up.
Then I’d put grindings/millings down, regrade rough, then tamp with plate compactor.
Just my suggestion. I think compaction might be important. Otherwise, you’re going to throw asphalt instead of stone.
I’ve used a snowblower on stone for 32 years, and 20+ on a front mount tractor.
Could it be more an issue of the shoes on the blower?
3,400
What is recycled asphalt? What we call road millings?
I have used road millings but in my case they don’t seem much different than crushed limestone. No snowblower here though. Just a back blade. Maybe I never put them down thick enough so stick together, or perhaps the sun is not hot enough here?
Hope it is an improvement for you. Definitely not as pretty as crushed stone, as you said.
What does a load of millings cost in your area? Just curious.
5,188
NOPE!
Do not ad anything to the recycled asphalt, or .....you will have an ugly mess!
6,328
RAP, Recycled Asphalt Pavement
Since it's a 'dry' mix, you do need to drive over it every so often. After a few months the RAP under the pickup was 'loose'. Simply driving over it a few times and it gets repacked. The more weight the better it gets packed.
Now IF you can get 'slag' from a steel mill that WILL pack down as hard as concrete after a few months. I could not break it apart at neighbour's lot. Even a 'real' excavator had to get under an edge,curl, then beat the stuff. magical stuff....once loose ,it's easy to spread, then tamp it down, becomes HARD again.....
5,188
I do not need to drive over my recycled asphalt at all, once it has been compacted.
awesome
Sep 16, 2018
320
215
ottawa
I am planning on rolling it. There's a rental shop close by and they have those big rollers just for that. Not sure how that costs yet
And I do have a good amount of left-over gravel. I have another project for it. I made 2 piles: 1 for clean gravel and the other one that's just crap.
The box blade is awesome. I like this thing already.
awesome
Sep 16, 2018
320
215
ottawa
Another successful project completed.
3 loads was too much.
PXL_20230725_182407109.jpg But I had another place I decided to "pave" so no leftovers except for that small pile that I'm gonna use for touch-ups.
Now I have to get a roller. Next month ...
awesome
Sep 16, 2018
320
215
ottawa
Nice work so far! Did you do more back dragging to spread, or box spread?
Only box.
I have a hydraulic top-link so it's even easier. I went from the street to the garage with the box tilted down, to scrape. Then the final pass was from the garage to the street tilted up. This way, I have a good slope. I have a laser to check the grade, so I'll double check with that.
I won't bother too much with low points right now. The roller, and a winter will do its work. I'll touch-up wherever I see puddles forming.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
351
665
NH/VT NEK
Only box.
How did this come out? I have to redo the driveway this week or next after having it dug up a bunch installing the conduit for solar, graded out the dirt they dug out and even "compacting" the trench with the weight of the tractor and filled tires......need to probably get at least 1-2 trucks of RAP if I can.
awesome
Sep 16, 2018
320
215
ottawa
I'm not too good at grading things so there are a few bumps. Winter will sort everything out. Next year I'll do a few touch ups
