Kubota B6000E front PTO flange and shaft to clutch
9,149
Don't know how I missed this before today.
And
FYI:
That joint was a MOD from a B7100 or the like, propeller shaft.
Berniew
Kuboto B6000E, Woods 304K mower, Massey Ferguson 135, Fleming flail mower
Apr 13, 2023
61
14
UK
Hi Dan, once again you are being most generous with your expert knowledge. I don't want the shaft or something else to break once I start to use the mower deck. Do you think if I leave what I have constructed so far but incorporate a Ruland Jaw Coupling, as in the attached picture in the middle of the new shaft it will be sufficient? I had, obviously incorrectly, assumed that the
original universal joint would take up any play.
Thank you for your advice. I look forward to your considered opinion. Thanks Bernie
5,620
original universal joint would take up any play. View attachment 107531 Thank you for your advice. I look forward to your considered opinion. Thanks Bernie
If you have room to fit it in a chain coupler is inexpensive and much more robust. I would like it better placed close to one supported end rather than in the middle of the span but you have a lot invested in your current machine work.
Berniew
Apr 13, 2023
61
14
UK
Hi
Hi Dan, I hadn't expected a replay till I got home this evening given the time difference but thank you. I will explore chain couplers but from what I have managed to look at so far they require a key in the shaft and I don't have the expertise, knowledge or equipment to create one on my shaft. I think there would be room at the crackshaft flange end as the PTO end would be too close to the underside of the radiator, once again I will have to explore tolerences. Thank you Bernie
5,620
I appreciate your limitations with machine work Bernie but in the long run you are going to be much happier with a keyed connection rather than a rigid welded joint. You can buy keyed shafting and if need be you can tack weld or pin the crankshaft half of the coupler to the shaft. I think it would handle the runout better than what you have now. Give me a little bit and I will draw something up for you. If I can draw it your friend with a lathe can easily make it.
Edit: On my PC and looking at your pictures again - much ceasier to see the details. Your coupler is closer to the bearing on the clutch than I thought. If you eliminated most of the runout in the hub and shaft assembly you may be fine with that OEM joint. I am not a fan of that design but you can always revisit that connection if it fails.
Berniew
Apr 13, 2023
61
14
UK
Hi Dan, thank you for all your input. I will try using the mower and see what happens and if it all goes wrong then it is a keyed shaft and chain coupler as you suggest. All the best Bernie
