Forestry winch too big for LX2610?
jtrout141
LX2610 Wicked 55 grapple-FDR1660 finish mower
Jul 10, 2021
Iowa
Have an LX2610 and am looking at getting a forestry winch. Found a Wallenstein FX90 local for a decent price but is it too much for this tractor?
The FX90 is listed as for 30-80 horsepower and the LX is a few horse below that. Any members have experience with skidding winch setups and if
used with a little common sense would the wallenstein work? Not going to be a huge logging operation just a clean up on a 10 acre spot that
getting trees out will be tough to access with just the tractor.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,995
2,364
Western MT
The youtube guy GP Outdoors has been using a winch recently with his LX2610. It might be helpful to see what he’s been up to with his.
jtrout141
Jul 10, 2021
Iowa
I checked that out,that igland is a 7700 lb winch. That's why I was considering the 9000lb pull wallenstein.
GrumpyFarmer
5,249
Good day. I have only drooled over and demoed (not bought yet 😉). I believe Hudson and farmi have models that are sized to HP rating of a B. I am not sure other brands. I demoed a Hudson and would most like buy from them when it comes time. On a B size machine(maybe others) I would recommend confirm the departure clearance when the plate / 3pt lifted…I’d make sure on the ground clearance for your use and terrain.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
Wow, learn something every day. An Iowa to PA transplant guy I worked with said Iowa was one big flat cornfield. Never mentioned any trees. He also said the biggest hill was where they piled up dirt to make an overpass for I80. :)
AKguy09
LX3310/ Cab 1950 F- Cub
Nov 22, 2017
108
ellicott, colorado
PTO power the LX2610 is alot short of that
Tughill Tom
B3200
Dec 23, 2013
1,489
2,182
Turin, NY
I have a Uniforest 30 M skidding winch on my B3200. It's done anything I've asked of it, big Maples and Ash no problem. It's got 26HP at the PTO and never any issues.
No problems with the lift arms, just a bit tight getting in to connect the drive shaft.
Maybe a diet would help me out there? NAAA.
g_man
Feb 3, 2023
411
1,937
NE Vermont
Most of the problems that occur when putting a big winch on a small framed tractor are due to the physical size of the winch compared to the tractor. Typical troubles are with drive shaft hook-up, 3ph can't raise high enough to get log off the ground or allow any clearance maneuvering in the woods, which takes up a big portion of the 3ph lift capability so not much left for logs, winch just to big for tractor to handle, the trator is to light so that the tractor gets pulled around or over instead of the log, and on and on. So - just make sure it will hook up to your tractor and you can get the winch up off the ground a decent height for clearance in the woods.
As far as hp goes - a low hp tractor will have no problem driving the winch but don't expect to get any where near 9000 lbs from it. The pulling power comes from the torque the tractor can produce at the 3ph. Your tractor will not produce the torque required.
I personally would not consider it unless the deal you found is an absolute steal. Just my 2 cents.
gg
g_man
Feb 3, 2023
411
1,937
NE Vermont
I have a Farmi JL290 winch on my L3010. So a 6600 lb winch on a 30 hp tractor with loaded rear tires that weighs 5000 lbs. Believe me that is plenty of winch and is sized right for the tractor.
I important thing to remember is it is the tractor torque that determines what you can pull. If I put a 8K or 10K winch on that tractor I could not pull more. Actually, because big winches are geared higher I would get less pull with a bigger winch.
gg
UpNorthMI
May 12, 2020
849
568
Up North, MI
I use a similar capacity, Farmi winch on my MX5800, I would never consider putting in on my
L3901 my key comment would be tractor weight, a winch can develop a lot of pull. If your smaller HP tractor reduces the winch capacity, then maybe it is useable.
I’ve had some scary moments with trees hanging up or falling where I thought my MX was going to get pulled over. Buy it and try it, you can always sell it on.
I do find a winch a massive asset when trying to pull trees out of woodland areas where you can not get a machine into the woodland. Good luck making your mind up.
9,118
Years ago my dad and grandfather picked up a wallenstein forestry winch for their L2250.
It was bought second hand and was designed to be used with a 45hp tractor.
The L2250 handled it without issue.
jtrout141
Jul 10, 2021
Iowa
Decided to give it a try anyway. Will get some pics when I get it cleaned up and operating.
Grandad4
Apr 5, 2016
447
195
Greensboro, NC
If the winch can fit on the tractor and the 3 pt can lift it, you "can" use it. You will have to limit what you do with it to the capabilities of the tractor, both the size of logs and the terrain you are on, because the winch is scaled for a larger tractor. You have more winch than you have tractor... it would be safer if it were the other way, so it's on you to be careful.
jtrout141
Jul 10, 2021
Iowa
Couldn't pass it up for the price and the fact it was only an hour and a half away. No plans for pulling big logs, this is to pull out mostly 6 to 10 inch honey locust from a part of the farm I can't use the tractor in because of the slope. Worst case it doesn't work and I sell it,
jtrout141
Jul 10, 2021
Iowa
Short update. Got the winch all hooked up and ran a few test runs getting a dead mulberry tree out first.
I think it will work as long as I work with the limitations of power from the PTO. Time will tell.
Grandad4
Apr 5, 2016
447
195
Greensboro, NC
Nice setup. Suggestions: 1.
Anchor the bottom of the winch as securely as possible - taking advantage of stumps, trees, rocks, etc whenever you can, for example, so a snagged log does not toss the tractor around
2. Pull straight back from the winch as much as possible. Pulling off angle to the side has a greater risk of overturning the tractor.
3. Safer to dismount and operate the winch on the ground instead of from the seat of the tractor. Standing far enough away so you are safe, of course!
4. Is there an adjustment for the clutch on the winch so it will slip before overturning the tractor?
GrizBota
Apr 26, 2023
1,147
733
Oregon
Needs a slipper clutch in the PTO shaft. Those are so much fun. Joking mostly. Glad it’s working for you. Be safe.
g_man
Feb 3, 2023
411
1,937
NE Vermont
This all reminds me of the time I was making a real hard pull with my 6600 lb pull Farmi JL290 and L3010. The winch drove itself into the ground like it should and became very well anchored.
Then the tractor motor bogged down to nothing. I immediately released the clutch rope and the tractor came up to speed again. I pulled the rope again and loops of cable started spewing off the winch drum falling onto the ground between the winch and tractor. It took me a couple seconds to figure out what was going on - when the motor bogged then came back alive it started running backwards. I shut it down quick enough to prevent any damage. They will happily run backwards except the oil pump and hydraulic pump are also going backward which isn't good.
So, if your tractor is well anchored this can happen even with a small winch but is more likely to occur with a small tractor hooked to a big winch with a strong clutch. Usually the tractor moves before the motor bogs that low but you will find out that there are endless strange things that can happen. Be vigilant, work slow, and start with small stuff. Give yourself time to get a feel.
gg
