Bacteria
4,134
Yes and yes. Growth is encouraged by water in the fuel, so first preventive measure is to keep tanks full to limit condensation as the fuel in the tank expands and contracts.
Many options. I only use this because it’s readily available locally. About $40 per container, but has lasted several years.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,408
2,335
I second the PS products. A little education on the subject:
4,320
Can bacteria grow in diesel fuel? If so is there a treatment for it?
I had a trawler yacht with 900 gal diesel capacity.
Always used Bio-Bor to prevent bacteria/algae growth.
3,098
Bio-Bor JF is a 20-Mule Team product….approved for use in jet-fuel aircraft…so it’s almost good enough for my Kubota. :p (I use it to treat the diesel in my storage tanks.)
Spores from yeasts (think of sourdough bread recipies) live in the air. As fuel is consumed…atmosphere enters the tanks. (Air above the fuel level in fuel tanks is called “Ullage”.)
The spores enter the condensation which occurs on fuel tank walls…and settles to the bottom of the fuel…where the spores germinate and grow…living in the water…eating the fuel…and POOPING their waste-products which is slimy and creates “mats” of slime (often mistakenly called “algae”). It clogs filters, injectors, and is corrosive to pumps, and tanks, etc.
Follow the directions CLOSELY if you use a biocide. Some of them, if merely “dumped” into the fuel instead of being introduced to the the fuel-stream when filling the tanks…will form “globs” of jelly and not perform as intended.
