Weight Box
TheMurf
BX1880.with loader and 48 inch deck. 1990 Gravel 12G Riding tractor.
Jun 25, 2022
160
72
Upstate New York
Need some advice..I recently purchased a new BX1880, with a payloader. Used it to spread 15 yards or so of topsoil. I decided after that, it required a ballist box which was delivered today..Land pride BX10 box to be exact .Question, how much weight to you folks use and what source of weight do you put into the box? I was thinking bags of softener salt with some cast iron weight in the bottom. If, your using the machine for topsoil, how much weight do you add ? Also, how much air do you add to the front and rear tires when using the payloader ? Shop manual doesn't specify..
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
Payloader? LOL. This is what I think of when I think about the word "Payloader". ;-)
In either case, your user manual will tell you what your 1880 can handle.
Personally I wouldn't put salt (or calcium or anything caustic) in there for fear of it leaking out and rusting.
I think I have about 400lbs off the back of my BX when I am using my payloader FEL
I fill the teeny front tires (yours are even teenier< is that a word?) on an 1880 to max allowed pressure every time I use the payloader FEL
6,284
1) never, EVER use 'salt' as ballast. sooner or later the bag'll split and YOU will have to explain to 'she who must be obeyed' WHY the grass died in a 'weird' way....
MY BX23s always has the 700# backhoe on as ballast, which is about 150# more than the bucket or forks will lift
Tires are pumped to whatever the TIRE says is the max. READ the tire ,please ! Not all tires were created equal, so you need to read the tire sidewall for the spec. Less will give you a 'cushy' ride.
Also when carrying a load up front, turn while driving NOT standing still, at least most of the time.
TheMurf
Jun 25, 2022
160
72
Upstate New York
Thanks guys. I will use my pellet stove bag pellets on top of the iron weights in the bottom of the weight box..I plan on lining the box with a heavy duty bag before I put anything in it. Just in case of any spillage. I guess a payloader was the incorrect terminology. I'll use front end loader in the future.
GrumpyFarmer
5,176
I’ve used playground sand with the BX I used to have, and currently on my current B. Sand is great…I also use on the drive if iced and scoop and spread right out of the ballast box and refill as necessary. As I recall I think I used about 300-400lbs for the BX. (I think if you have chunks f iron/lead or even rocks to take up some space that would be ideal). With the sand I keep the bottom 2/3 in the bag, and then fill to top off…it fills in the empty space that way and leaves me space to scoop out if I need to spread or take a bag out.
JeremyBX2200
BX2200
Aug 3, 2020
506
455
Indiana
I use my box blade. I think it weighs about 300lbs. It does well, Gonna make a tray for the top so I can add more weight. I have spread about 40 tons of topsoil and another 20 of gravel.
I always inflate the tires to the max allowed.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
Don't take it personally. I was just having a little fun with ya my friend ! ;-)
TheMurf
Jun 25, 2022
160
72
Upstate New York
VE9AA, I didn't. I laughed when I saw your picture of the payloader.
SDT
Apr 15, 2018
3,678
1,403
I have two ballast boxes that I use with tractors of different sizes.
Mine are filled with bagged playground sand from Lowes. Add/remove as desired for whatever reasons.
I store my ballast boxes (and just about everything else) on moving dollies from HF. Easy to move around on concrete floor and easy to hitch/unhitch.
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
461
534
NE Ohio
The ballast box I have came with a label saying add 300 pounds for a BX and 400 pounds for a B.
I've got 300 pounds of pea gravel in mine.
TheMurf
Jun 25, 2022
160
72
Upstate New York
Thank you JimDel.. I know the box will hold 600 lbs but I really don't believe that's required. It manly spreading some top soil in the yard and mulch. I know the first load of soil was a learning experience without the extra weight. Slow,Low on the bucket height, back down the hills, took some time but it was worth the effort. The extra stability is worth the price of the box. Safe than sorry.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
The first time I tried to lift something really heavy at an odd angle with my forks, one rear tire came off the ground.
Shorts turned brown. :poop:
An hour later, (after change of shorts) I ordered a ballast box.
Only takes once !
Be safe
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,153
1,144
E.
sounds right to me.... in grade school in our farming classes we were taught on the 3pt we should have 1/3 to 1/2 the weight that the bucket and load in the bucket weighs. higher side if you be 2wd or on soft ground.
I only use my ballast when needed.
TheMurf
Jun 25, 2022
160
72
Upstate New York
Ve89aa, said
"The first time I tried to lift something really heavy at an odd angle with my forks, one rear tire came off the ground.
An hour later, (after change of shorts) I ordered a ballast box."
Rest assured, you weren't alone in that situation. Same happened to me, uneven ground was part of the problem.. I started taking half buckets full of dirt. Once I was finished, I took a ride out to our dealership and gladly paid for the weight box.. The salesman said the always stock them, they had four in the back yard. He had sold two in the last couple of days.. Well worth the safety if your going to use the FEL..Thank again to everyone for the advice. Good folks here on the forum, with lots of knowledge to share.
Donystoy
Dec 10, 2013
735
378
Binbrook, Ontario
I just recently purchased a weight box as well and plan on putting gravel in it. I think that sand would leak out a bit over time through cracks. I opted for it to keep the overall length of the tractor down when maneuvering in the woods. I do have other attachments that I could use for counterweight but not as compact as the weight box.
SDT
Apr 15, 2018
3,678
1,403
That's why I leave the sand in the bags.
TheMurf
Jun 25, 2022
160
72
Upstate New York
Just a thought, get a good heavy duty contractor bag and line the weight box before adding any loose material into it . That and leave any sand, salt, pellets,etc, in the bags they come in from the manufacturer..
JimDeL
Aug 31, 2022
461
534
NE Ohio
Not a really good idea. The weight box has drainage holes to allow rain, etc. to escape. The bag will hold that water in. Worst case: Mold, otherwise just a mess when you finally do remove the weight.
jkrubi12
Sep 24, 2012
403
302
right coast
I know, I know, I'm a cheapie....Found a new-condition Kubota ballast box on FB Marketplace, used big rocks from the yard to fill it. Mine is the older style, apparently doesn't work with a QH. I just have to remember to pick it up before I try to drive away! :rolleyes:
GrumpyFarmer
5,176
I had one of the odd shapes that did not work with QH…actually I sold it when I added Pat’s and it did not work with Pat’s. There should be a pics if you look through the ballast box threads(there really good ideas in the older threads that some have done…much better than what I did on the cheap with reclaimed materials, but its functional for my uses). I put cheap inner framework in it which held the sand in the center then left the ‘ears’ as storage trays and I had a lid to keep water out…I added a hitch too. Good luck and share some picks back what you do with it.
Here’s old model and new…
