Reenforcing bucket cutting edge
BonnySlope
BX2380FEL, Add-A-Grapple, Box Blade, Rake, Rear Blade, HR12 Tiller, Flail Finish
Apr 11, 2021
140
122
NW Oregon
Back in December 2022 right after I purchased my BX2380 I purchased a six foot bucket cutting edge. My plan was to shorten and drill and counter sink Machine Allen head bolts with serrated locking flange nuts. Well, I finally finished it up after having extra flange nuts after completing wheel weight mounting project.
5,161
Nice work, but why didn't you just buy the Kubota part? Yours appears to be a heavier grade of steel than the Kubota part, but I have been satisfied with the quality of the Kubota edge for my use.
Nicksacco
Sep 15, 2021
757
492
Bahama, NC
Wow! Great job and it looks great! Have you tried it yet?
Plow Bolts - is that what you used?
And you can usually find these cheaper at a farm store.
BonnySlope
Apr 11, 2021
140
122
NW Oregon
No haven't had a chance to try it yet.
I used 82 degree tapered Allen head machine screws/bolts counter sunk to wear surface. They use a 5/16th allen insert tool.
cthomas
LX2610 HSDC
Jan 1, 2017
848
563
La Farge Wi
Why-O-Why are you using SAE bolts on a Japanese tractor? Yes, I know it was made in Georgia.
dlsmith
BX2230, LA211
Nov 15, 2018
1,313
952
Goshen, IN
Looks just like the Kubota edge I bolted to the new weld-on cutting edge on my BX2230 a while back.
BonnySlope
Apr 11, 2021
140
122
NW Oregon
Thanks, Kubota's bolt on bucket lip is pretty good and the stock edge is fairly durable and hold up. My older B5100DX lip held up well. The only reason I installed was because it fit better on my BX then holding the wall up :)
BonnySlope
Apr 11, 2021
140
122
NW Oregon
?, if your referring to me saying takes "5/16 Allen tool". Which is used to hold bolt in place while torquing nut in place with blue lock tight, just because it was there.
It's a blank hole that I put the bolts through. Kubota hardware kit for lip install kit (carriage bolts and nylock nuts) not sure what threads are, possibly Metric. or just hardware installing dealer has or puts together.
It's not like mixing Phillp screws and slotted screws when assembling wood project. ;):D, keeping it light.
