Work fast!
Yooper
3901 LA525
May 31, 2015
1,612
729
NE Wisconsin
I’m seeing more tracks on farm equipment every year. Makes sense. One wet fall a few years ago they were the only ones that could access the corn fields for harvest. Even had tracks on the wagon. We’ve come a long way from the Farmall doing two or three rows at a time.
6,461
It's interesting that many folks think running a tracked machine on the dam when building a pond will compact the material tightly. Just the opposite is true. The surface area of the tracks spread out the weight much better then machines with tires. Wide tracks are used on heavy crawlers on ice for that reason.
3,922
Yup I tried to explain that to a contractor that was "compacting the floor on my pole building,, he couldnt understand because it looked so nice. After we had a come to Jesus talk he brought in a tamper and 3 more tri axles of fill,,,
Flintknapper
L2350DT
May 3, 2022
1,915
2,409
Deep East Texas
While it is true a tracked vehicle/machine exerts less pressure per square inch...that doesn't mean it isn't a viable method to compact soil. What matters is IF the amount of pressure is sufficient for the job at hand.
Where earthen dam building is involved it might very well be quicker/easier/better to use the large footprint of tracks to compact the soil evenly. You don't try to compact layers (depth) of soil greater than the machine is capable of. If you do...that is operator error. Just saying that 'tracks' are perfectly fine for many applications.
